Drivers who have or have had Toyo R888R tires
Old 06-30-2021 | 06:04 PM
Saudio's Avatar
AMG GT C
Originally Posted by Bijan Kohan
I am also looking to upgrade my stockers soon. I am considering the R888R’s. Don’t track much and the GTS is not my daily driver.
I am waiting on my HPFP do arrive, as have it installed along with an E85 tune and possibly meth just for extra cooling. Once I have attained my power goal, it will be time to upgrade the tires.
Regarding tire size how about going with 325/35/20 on the rear? If I have H&R’s, will it cause rubbing? I just thought a bit of a larger side wall can add a bit of cushion in potholes/cracks etc, and fill up the wheel well a bit more which are two nice benefits.
Any thoughts?
The 325's are the only size Toyo says will work with my GT C because the 315's have too low a weight rating. I'm also supposed to fill the 325's to 39 pounds instead of 36 because the weight rating is 102 and the factory calls for 103. Don't know if the GTS would have the same constraint.
Old 07-01-2021 | 03:50 AM
Mazspeed's Avatar
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
Originally Posted by kumizi
PS4S is probably the right choice for 90% of people.
R888R for those with high hp that want every last bit of grip.
The cup 2 is a better track tire all day long than the r888r
Old 07-01-2021 | 03:53 AM
Mazspeed's Avatar
Why is anyone using the r888r when the trofeo r is available?
Old 07-01-2021 | 04:56 PM
kumizi's Avatar
Designo White AMG GTS
For straight line traction...R888R is much better than Cup2 and Trofeo R.
Old 07-01-2021 | 05:28 PM
Mazspeed's Avatar
I agree, for straight line launches, it’s a better grip going forward. That’s it’s 1 and only advantage from the other tires you mentioned. For track duty, and all other dry handling it’s far down the list including comfort, noise, and wear although it’s about on par with the Trofeo R as far as wear. None of those tires are nearly as loud as the R888Rs.
Old 07-01-2021 | 05:33 PM
kumizi's Avatar
Yes. This thread is about straight line launches.
Old 07-01-2021 | 05:58 PM
  #32
Mazspeed's Avatar
Perhaps that and road noise. There is much more to consider than grip from 0-60.
having said that. The trade off isn’t really worth it. When you’re on a forum it’s good “if you can do this as a general rule” is to give the person asking the question the best answer forward. The R888R is not a good tire for cars above 3500lbs. It struggles with heavier cars due to the thin sidewall.”which makes it great for launches” It’s not great on the track, it’s wet weather handling is poor, it’s very noisy, it wears fast, but in a straight line it’s better than the others. Now I like to think I gave him as much info as possible than just saying the tire is good for launches. He needs to know the good and bad of the tire in question.
Old 07-01-2021 | 09:32 PM
  #33
Saudio's Avatar
AMG GT C
I already have them on the way. So I'll report back with my impressions after I get them on the car.
I don't track my car. I rarely take it on long trips (I trailer it to events). My fun is mostly short runs on weekends and evenings. I join friends for drag strip days and I have another friend who shuts down his airport a couple times a year so we can do 1/2 mile speed runs. I have a stage one tune so I have more torque than I can manage. So, this might be the tire I want.
If it isn't, I'll craigslist them and get different tires. No biggie, and I enjoy experimenting.
Old 07-02-2021 | 12:05 AM
  #34
Mazspeed's Avatar
Report back. Always good to hear others experiences.
Old 07-02-2021 | 02:03 AM
  #35
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
Value and tire life. A set of R888R are maybe $600 cheaper and more ‘streetable’. Agree that Trofeo’s (and Sport Cup 2’s) are quicker on track.
Old 07-02-2021 | 03:02 AM
  #36
Mazspeed's Avatar
Tie life is about the same. Both are shaved. I wouldn’t call a louder tire that is poor in wet weather more “streetable” how is it a better street tire than the Trofeo R? These isn’t an auto manufacture that will use the R888R as optional equipment on their cars. The Trofeo R has been optional equipment on a few cars. Although I would hardly call the Trofeo a streetable tire, but it’s certainly more so than the R888R.
Old 07-02-2021 | 09:37 AM
  #37
Saudio's Avatar
AMG GT C
Have you had R888Rs on any of your own vehicles?
Old 07-02-2021 | 10:43 AM
  #38
Mazspeed's Avatar
Yes, plus we have used them on our race cars.
AMG 17GT (07-02-2021)
Old 07-07-2021 | 07:23 PM
  #39
Saudio's Avatar
AMG GT C
So, here is report one: I had the tires mounted today, and I'm happy to report that the noise they make, while noticeable, is well within my level of tolerance, and I'm a real stickler about noise. In my GT-C, with the top down, I hear no tire noise at all up to 50 MPH. At 60 or so, you can hear some noise, but it is relatively low pitched (not a whine) and is forgettable. At 70 or more, the wind noise exceeds the tire noise, so no problem there. I might find the noise more noticeable with the top up, but I almost never drive with the top up.
The installer advised me not to accelerate sharply for 2 days to allow the wheel mounting lubricant to dry, or else I could spin the wheels within the tires and throw off the balance. That was a new one for me but it makes sense. So after I'm able to drive it at 100% I'll report again.
Also, the 325 30/20 fits perfectly even though the car comes with 305 30/20. Toyo recommends this size because they do not make a 305, and the 315 does not have sufficient weight rating.
Old 07-20-2021 | 05:58 PM
  #40
kumizi's Avatar
how are the tires hooking up?
Old 07-20-2021 | 06:03 PM
  #41
Saudio's Avatar
AMG GT C
Noticeable improvement, but I have not had a chance to do any speed runs to see if the difference is measurable. One thing that is very apparent is the tires feel much more planted and stable at high speeds. With the stock tires the front end seemed a little squirrelly over about 90 MPH.
Old 07-20-2021 | 06:54 PM
  #42
Case1906's Avatar
Mazspeed--Missed this earlier and I respect your opinion as a racer. For "streetability" purposes I do think treadwear is better for the R888Rs. As for rain, they are probably equally poor. I didn't factor in rain because I usually don't drive much in the rain. I don't find the R888R road noise to be nearly as offensive as the old R888's which are crazy loud. It's just a value thing for street use taking into account some economics. A set of rear R888Rs for my GT will cost me $450 more than the Pirelli's.
Mazspeed (07-22-2021)
Quick Reply: Drivers who have or have had Toyo R888R tires
