Transmission fluid alternative from Valvoline?
Old Jan 27, 2022 | 11:18 AM
descartesfool's Avatar
AMG GT-S, AMG C43, Ferrari Roma, Maserati MC20, Genesis GV70 Electrified
While searching for the DCT transmission fluid for my GT-S from Ravenol ATF DCT-F3 which is rather hard to source, I decided to check its specification. Its PDF data sheet says:
"RAVENOL ATF DCT-F3 is especially developed for use in 7- dual-clutch transmission GETRAG Powershift 7DCL750 for Daimler Specification MB 236.25."
So I then searched for a fluid that meets the same MB spec of 236.25 and found this from Valvoline:
https://www.valvoline.com/en/product...smission-fluid
Data from Valvoline says:
Valvoline™ Dual Clutch is a full synthetic transmission fluid specifically engineered to protect and prolong the life of dual clutch automatic transmissions. Recommended for use in the following applications: BMW 83 220 440214, Ford M2C 936A, MB 236.21, MB 236.25, Volvo 1161838, Volvo 1161839, VW G 052 182.
Has anyone heard of this DCT fluid, and if they say it meets the MB spec for the DCT, would it be an alternative choice? Having had experience with DCT fluid changes in my 2009 Nissan GT-R, I know I had zero issues in over ten years of hard track use with an alternative fluid than Nissan's OEM fluid since I used Pentosin FFL-4 made for BMW, so there might be an easier to source product than the Ravenol.
Valvoline data sheet says it is specified for the Ferrari 7 speed from Getrag which is the same transmission as in the AMG GT-S.
Old Jan 27, 2022 | 11:57 AM
chassis's Avatar
2017 GLE350 4MATIC
Have you used the operating fluids site? Former bevo site.
I would buy it from the dealer.
Old Jan 27, 2022 | 01:38 PM
The MB BeVo site lists Shell TF DCT-F3 as the transmission fluid for the AMG GT. But try to find it.
Old Jan 27, 2022 | 01:53 PM
chassis's Avatar
2017 GLE350 4MATIC
What about calling the dealer? MB part numbers are listed on the operating fluid site.
Old Jan 27, 2022 | 04:05 PM
ronac's Avatar
AMG GTS
I used Motul in mine.
https://www.pegasusautoracing.com/pr...?Product=MT237
It also has the same specifications for 236.25
Old Jan 27, 2022 | 05:02 PM
Main purpose is to avoid the dealer and do a DIY.
Motul DCTF is another good alternative, used lots in Nissan GT-R DCT's
Old Jan 27, 2022 | 05:06 PM
Acta_Non_Verba's Avatar
Bentley Continental GT; AMG GT
It is what I am using since the Shell is not available anywhere.
Dealer purchase at most dealers is not an option as they purchase this fluid in bulk, not in 1L bottles.
Old Jan 30, 2022 | 08:15 AM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
I found the other fluid more difficult to attain.
Old Feb 2, 2022 | 09:23 AM
I am NOT making a recommendation to substitute Motul so, my "disclaimer". I am confident using it in my car but a few words on these "substitutes".
When a trans manufacturer builds a product they end up with "exclusives" with the fluid suppliers. In that agreement the manufacturer agrees NOT to test or support any other fluids, but the fluid maker in the agreement. Other companies MIGHT copy the formula, mark the product as "compatible" with the OEM product, and that can be a double edged sword. It might or might not actually be compatible, but the other company is in a very low risk position any damage could result by using their substitute, so they go with it. BTW, Motul IS marked compatible with MB 236.25 spec.
ZF is notorious for doing this. I've changed a number of ZF 6HP and 5HP transmission fluids where only "Lifeguard" fluid is prescribed. But on the "Streets" we knew some other products worked with no issues at all. In the case of the 6HPxx a Motorcraft Mercon SP. The way we happened on SP was Ford used the ZF 6HP26 in the Lincoln SUV and their fluid change recommended SP, Same trans that was in numerous Euro and Asian cars.
So, this is not a recommendation as much as a caution to proceed at your own risk BC, ultimately, you'll own it anyway, not Motul.
Old Feb 2, 2022 | 10:24 AM
Tdott's Avatar
4wheels
DCTs tend to be more picky on fluid, I'd stick to something as close to possible as the oem fluid or just get the oem one.
Old Feb 2, 2022 | 11:03 AM
Yes, that is why I was careful with a disclaimer above. Not recommending it at all, but I'll experiment with it. If the Shell was available, this wouldn't even be a discussion on my part.
Old Feb 2, 2022 | 12:18 PM
Katie22's Avatar
You changed the spark plugs. The trans will be a walk in the park. Just remember my experience and that I ended up adding a bit more fluid to the trans to get rid of the jerky stops.
Old Feb 2, 2022 | 12:54 PM
Hahaa....Yeah those spark plugs are a devil.
Yep...have it down in my memory banks.
BTW Katie, do you remember the quantity that you drained off? How much came out in the initial drain on the DCT side?
Old Feb 2, 2022 | 12:59 PM
Katie22's Avatar
I had a impeccably clean drain pan that a weighted after the drain and then installed the exact same weight back into the trans. Then I did the warm up with the scan tool and when it got to temp I did the drain off.
Old Feb 2, 2022 | 01:03 PM
OK, so you weighed it but not the actual quantity in qts or liters?
Yes, I have a scan tool that will give trans fluid temp. I'll follow WIS as I have it.
Old Feb 2, 2022 | 01:07 PM
Katie22's Avatar
Correct I did not record the exact quantity since my scale is very accurate. As far as the drain off at temp. I ended up adding a bit more to get the drain off at temperature. Of course as I said it really needed about 10oz more than what WIS directions said, At least that was my experience.
As you probably know WIS is a bit strange. If you put the capacity for engine oil as they say you will get the message please drain off a quart. That happened with my 16 Maybach and the GTC. So I learned from this and now days add one quart less than what WIS says.
