Motor dies after auto braking ?!
Anyone else have this happen ? That was super lame and annoying. potentially dangerous depending where it kills the motor. Was embarrassing but relieved to realize that’s all it was.
Can "Disable" it in the Menu for highway, but for Track, there may remain elements of the nanny, tightening up your seat belt suddenly, etc
Can try taping over all the front and rear bumper sensors, and the larger 3 Point Star sensor in front grill - this method has worked for some.
I set the dial to 3 reds seems to disable it 👍. not sure what i think about that “feature”
I see this differently. Knowing what I know about tuning and what is available to the tuner, the tune would be at the top of my list. One corrupted data table either accidentally, or sometimes via a corrupted download is all it takes. I know you're with a known aftermarket brand, but I've run across some real "tooners" out there that thought they knew what they were doing and didn't.
I am not suggesting the tune is the absolute fault, but for me it surely is a possibility.
But clearly there's a bigger problem with the engine dying, which definitely should not happen. I'd personally get to the bottom of that first.
Another possibility - try to get a deep scan done. You'll need a more sophisticated diagnostic tool. The complexity of the controller area network protocols in this car can cause controllers to dropout intermittently or partially. You can end up with one or more features that won't work as designed. With U-codes, you might not see any dash warnings or other indications there are faults occurring on the CANBUS.
I recently did a thread on this topic
https://mbworld.org/forums/coupe-roa...0-u103100.html
After a routine deep scan of my car, I found multiple CANBUS errors emanating from the AMG gateway module. There were no dash warning signs/messages of any kind, but I found some modules were not communicating or intermittent on the network. I went through the details of getting to the bottom of it in the above thread.
Maybe try a deep scan, but still don't discount the tune.
1. Based on track experience, when you don't turn ESP fully off, ABA and Pre-Safe continue to operate. Try it. The rare times, I forget to fully defeat it, I am quickly reminded if I am late braking behind someone in a corner.
2. See page 61 of the 2018 owners manual as it says the following:Characteristics when ESP® is deactivated
If ESP® is deactivated and one or more wheels start to spin, the÷ESP® warning lamp in the instrument cluster flashes. In such situations, ESP® will not stabilize the vehicle.
If you deactivate ESP®:
- ESP® no longer improves driving stability.
- Engine torque is no longer limited and the drive wheels are able to spin. The spinning of the wheels results in a cut for better traction on loose surfaces.
- Traction control is still activated.
- Adaptive Brake Assist is unavailable.
- Active Brake Assist is also not activated if you brake firmly with assistance from ESP®.
- PRE-SAFE® is unavailable.
- PRE-SAFE® is also not activated if you brakefirmly with assistance from ESP®.
Remember that you have to do the whole sequence above every time you turn off the car.
It’s a good idea to leave the TC with lots of Yellow lights showing initially until you get used to having ESP totally Off, but the car extremely balanced as long as you’re careful with your right foot.
I think i’ll get to get a deep scan and talk to the tuner and see if they have any insight.
Been to track once right after i got the car a few weeks ago. Played with car in Race and sport plus. Turned ESP off and had three reds. seemed to get rid of the ABA and the belt tensioning. car felt solid and predictable. On my C7Z I usually put it in PTM sport 1 and 2. tried race a few times and was non eventful but o like having the safety of active handling if i screw up. Sounds like with ESP off you lose MB version of active handling.
