Aston Martin Vantage owner checking in...
Old Sep 8, 2022 | 06:57 AM
ArabianOak's Avatar
2022 Aston Martin Vantage 007 Edition
Hi Gang,
Recently purchased a 22 Aston Martin Vantage 007 edition. Car is fantastic and I knew I would enjoy it considering it has lots of AMG stuff on it. The Aston Martin forum is pretty quiet and I was hoping to get help from this forum if possible. As many of you know the AM Vantage has the motor, trans and ecu from the AMG GT cars. The interior shares a good amount as well (center console, menu options etc). That being said I did have a few questions...
1. What coding software do you guys use for the newer AMG GT cars (reset service light, turn off autostart/stop feature etc). I have used bimmercode for my previous m850 I had and it was fantastic.
2. Why is the AM Vantage slower than the AMG GT cars...i know my trans is tuned differently than the AMG GT cars but the AM Vantage is also a good amount lighter...just curious if anyone knows the answer to that.
Old Sep 8, 2022 | 07:19 AM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by ArabianOak
Hi Gang,
Welcome! Please post a photo of the AM.
Old Sep 8, 2022 | 07:24 AM
ArabianOak's Avatar
And a video of my car at the dealer with James Bond music...lolololol.
https://www.youtube.com/watch?v=GcSt4clhFnU
Old Sep 8, 2022 | 08:28 AM
UCIMBZ's Avatar
E55, 380SL, GLA 250 Sport, AMG GTS
Congratulations. That "Bond" panel though lol. Also it's slower because the manual trany version can't handle the power. You should be able to unleash the power by some safe and easy ECU upgrade. Look into Eurocharged and such.
Old Sep 8, 2022 | 08:32 AM
ArabianOak's Avatar
Yes, I did the eurocharged tune (which was a very painful process) and it added half a second and 6mph to my 1/4 mile time. Car pulls nice...here is a video to 165MPH
Old Sep 8, 2022 | 11:13 AM
Wolfman's Avatar
Super Moderator
Welcome! Great looking car!
If memory serves, the car has a ZF 8 speed slush box, not a DCT.
The engine was detuned but you already took care of that with a tune.
The ZF is fantastic but read that AM didn’t do the best job on the software matching, something that BMW nailed.
Old Sep 8, 2022 | 11:43 AM
Acta_Non_Verba's Avatar
Bentley Continental GT; AMG GT
Hi Gang,
Hi ArabianOak,
Beautiful car! Great pics!
A couple of things on your Qs:
Regarding the service reset, this is accomplished through a series of steering wheel button sequences. There are two different processes, one for the original AMG GT platform up until the "digital" version change, then a different sequence for that. I'm sure if the program is the same, then your car would use either the exact or some variation of the newer sequence. If you can post a complete pic of your steering wheel I might be able to suggest a button sequence for you to try, although I can't imagine you're needing a service if this is a pretty new car. Past the button sequence, the service reset can also be accomplished via a deep scan tool with MB programming (only a guess if AM used this SW system exactly the same as MB).
Regarding the auto stop/start - this is something I can tell you with certainty, on the MB version (and if yours is the same) you don't want to try to bypass this. Just get in the habit of starting the car, then pushing the green button. MB made this system integral in the battery management module. The closest some got was to completely disengage the BMM, then numerous U-codes get set.
On the question about performance, your platform almost uses the complete drivetrain from the AMG GT, but not the trans. As far as I know, your car has the ZF 8HP75 (updated version) and does not use the 7DCL750 DCT. The DCT is likely to be the reason you're not neck to neck with an AMG GTS. Past that, essentially your motor is the same output as the 503hp version of the AMG GTS.
Hope some of this helps you.
Best,
Acta
Old Sep 8, 2022 | 11:47 AM
Sorry for the dup Wolfman. I must have been typing when you were posting. Didn't mean to repeat.
Old Sep 8, 2022 | 11:59 AM
Wolfman's Avatar
Super Moderator
You added much more detail. Thanks.
The ZF tranny is likely quick enough to match the DCT but the programming isn’t matched well enough to the engine.
Old Sep 8, 2022 | 12:13 PM
ArabianOak's Avatar
Hi ArabianOak,
Best,
Acta
Thank you! Yes, my old car was an amg gts and with tune it ran 11.28@128. So my AM is close but still not as fast. haha...I like the trans but it does feel a little lazy sometimes, which I know is in the tuning. here is a pic of my steering wheel...
Old Sep 8, 2022 | 01:18 PM
Hi Again,
The steering is a completely different layout than the digital AMG version. It's more like the original steering layout, but with buttons on the opposite sides. I saw this video and thought it might be worth a try for you. It's pretty easy to follow the steps in it and the buttons seem to match yours.
First, a couple of simple reminders that impact the reset on the AMG and just might be the same. Before you begin the sequence in the video:
1. Make sure all doors, hood, hatch are closed as you are sitting in the driver's seat.
2. When you're following these sequences, you are pushing the start button WITHOUT depressing the brake as you just want to put the car in accessory mode and not start the engine
3. He says it in the video, but one of the first steps is that you must be on the mileage screen before you start the sequence.
Good luck with it, let us know how you did. If it works, maybe you can take it over to the AM site for help there. BTW, depending on which AM site you are on, I visit one of them occasionally.
Good luck,
Acta
Old Sep 8, 2022 | 01:28 PM
ArabianOak's Avatar
yep, this worked! Thank you @Acta_Non_Verba ! I am not due for service but I wanted to find out how to access the menu...awesome!
Old Sep 8, 2022 | 06:09 PM
AR_motorwerkz's Avatar
MERCEDES AMG GT, MERCEDES CLS63 AMG, MERCEDES G63 AMG, MERCEDES CL63 AMG
Oh man! Hands down! Nice AM! Welcome to the club!
Old Sep 9, 2022 | 12:37 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Very cool edition of a great car!!! Nice! Enjoy the car and pics were great!
Old Sep 9, 2022 | 12:42 PM
hyperion667's Avatar
2012 CLS63
Bloody hell that's awesome!!
LOVE this little touch. (from The Living Daylights) One of my favorite Bond cars
