AMG GT-C (and others) - Lithium Battery Replacement
Old Mar 4, 2024 | 04:49 PM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
Friends,
Have any of you replaces the lithium battery with an Antigravity lithium battery? I have done so and the car works fine, but I still get the annoying battery message after about 5-10 minutes of driving. It remains charged etc.
Does anyone know what the connector (lithium CAN equivalent?) from the original battery is and how it works? Ideally, I'd like to wire that up properly to the Antigravity instead of "coding an AGM"
Alternatively, a friend has the diagnostic tools etc and can help me code the battery to AGM, but I'd rather find out how to make the connector work if possible.
Sorry I know there are several battery posts, but I couldn't find one that explained how that connector works and how to use an aftermarket LITHIUM battery with no error. Thanks!
Old Apr 2, 2024 | 10:27 PM
DesertDog18's Avatar
2018 AMG GTC
I just went through a battery change on my 2018 gtc, ended up buying the mb lithium. Before I made a decision I spoke to the guys at anti gravity and they do not have a connector for that. They told me no one makes it. I also traded messages with Benz Ninja, he can permanently code out the error code you’re getting. I recommend contacting them. They offer single repairs and a membership plan.
Old Nov 17, 2024 | 01:12 PM
projects's Avatar
SL55
No, You can't use aftermarket battery. there is a computer inside battery talk to engine computer with special code by LIN bus to control charging, Also li-ion battery needs all kind protection things to prevent damage/fire. I even tried Porsche Li-fe battery with computer, does not work as program inside battery is different.
Old Nov 17, 2024 | 02:00 PM
MBNRG's Avatar
I believe there is a way you can.
But need advanced coding, via BenzNinja or similar, and then can even switch battery to Lead/AGM
Old Dec 10, 2024 | 01:55 AM
vandoche63's Avatar
c63 w204 2008
ma batterie au lithuim viens de lacher au bout de 10 ans je viens de la remplacer part une neuve chez mercedes 2500euro
Old Jun 17, 2025 | 04:34 PM
gtstodd's Avatar
GL550 / AMG GTS
He coded my conversion
Old Jun 19, 2025 | 05:13 AM
Kevin#34's Avatar
AMG GTR 2021 (Euro version)
~ 2500 $/ € for the OEM lithium battery is crazy!
really no chance to replace it with a "simple" AGM battery without having DTC or other issues?
Old Jun 19, 2025 | 07:38 PM
gtstodd's Avatar
GL550 / AMG GTS
Only BenzNinja.com can. They did mine.
