Time to warm up before driving?
I daily my AMG GTR and usually give it 30-60 second before backing it out of the driveway. Drive lightly until oil and fluids are warmed up, then drive normally.
Been doing this for my other sport cars in the past and never had issues. Most recent one being a Corvette C7 with 52k miles. Thoughts?
no need to leave the car running for longer to start up. Thats actually counter productive and not good.
So, my guy (Mercedes Master Mechanic) said to just drive the car. The sound is the the oil coming to pressure and the cams changing their positions. While I do drive easier until the temps are good - I have been told many times (including my old Porsche Turbo S) that it makes no sense to warm the engine and not warm the rest of the drive terrain.
In the meantime, I am using enough throttle after 2 minutes, to barely get the rpm into the next gears range(about 2000 rpm). Now I am tooling around at residential speeds of 35-40 mph, until the engine oil is warm(10 minutes and 158deg).
Then I use no more than 3000rpm, until the transmission oil is warm(about 20 minutes and 128deg).
After everything is warm, use whatever rpm I may need.
On the cooldown, entering my neighborhood streets about 5 blocks from my house, I let the car idle, shooting for a 2 minute cooldown at idle, by the time I reach the driveway, or whatever other destination I am stopping at. If I haven’t observed my 2 minute cooldown yet, I park it and let the engine run at idle to round out the 2 min.
Some say a 30 second warmup and cooldown of the turbos are sufficient, but it goes against all my conditioning and experience with turbines.
The other reason I don’t idle at all, out of gear, after starting, is because with direct injection, none of the fuel(which is rich at this point) is being sprayed onto the backs of the intake valves. So any EGR or excess oil on the backs of the intake valves now have a tendency to coke over with time.
Don’t hate the player, hate the game!
I want to add probably pop the hood and check all the fluids and stuff such as oil level, coolant, (obviously do these both before starting the car) it is a good habit.
The other item I failed to expound on, is another reason why it’s not good for your car to idle after start, in neutral. As mentioned the fuel mixture right after a cold start is probably the richest the car will see. The rich mixture goes into the cylinders, and washes out/ dilutes whatever oil is present in the cylinder, and the wear observed there is the highest during normal operation. Putting the car in gear right away puts a load on the engine, reduces the rpm of the(choked) startup, and starts leaning the fuel mixture quicker.
It probably doesn’t make a huge difference in the short run, but in the long run could significantly reduce overhaul costs.
