A GTR has landed in my garage!
I picked it up in its hometown (Stuttgart) and brought it back to its new home here in Italy (about 650 miles)
Random thoughts:
- Absolutely stunning looks! (But I already knew that, and it’s one of the reasons I decided to buy this car to replace my current TT-RS)
- I was a bit worried about comfort on the road, but all in all, it exceeded my expectations. The suspension is definitely on the firm side even in Comfort mode, but the seats aren’t as uncomfortable as I feared after reading some posts here on the forum
- The engine is seriously impressive (even though I’m coming from a car that goes 0-60 mph in 6.9 seconds), and even though it’s equipped with a GPF, the sound isn’t bad at all (though I still haven’t figured out if the sound really comes entirely from the engine, or if part of it is fake sound coming from the speakers)
- Fuel consumption: it guzzles gas like an aircraft carrier!
A few things I unfortunately miss a bit compared to my 2020 TT-RS;- The LED matrix headlights, first and foremost! The GTR’s headlights aren’t bad, but when driving at night, Audi’s matrix headlights have a significantly more powerful beam, both in terms of depth and width
- The brakes (steel system) don’t stand out for their initial bite (though it’s worth noting that my TT has 370 mm rotors, Ferodo Racing DS 2500 pads, braided steel lines, and Castrol SRF fluid, and it’s definitely about 150–200 kg lighter)
- The GTR’s seats lack the extendable section, which supports the lower thighs and greatly improves comfort on long trips (especially if you’re quite tall, as I am); I don’t understand how Mercedes could have overlooked this!
- The multimedia system (navigation in particular) is decidedly less intuitive than Audi’s, and also less functional (you can’t enter personal POIs, and the navigation voice sounds very unnatural and primitive), while the optional Burmeister audio system (though not the top-of-the-line model) has good clarity but, in my opinion, lacks a bit of power (and it’s also true that those leaning toward a GTR are probably more interested in the sound coming from the wonderful 3-outlet titanium system than in what comes out of the speakers).
- Last but not least, it doesn't seem possible to change the fuel consumption display (which is quite annoying to me) from liters per 100 km to km/l (the equivalent of your mpg)
The next step will be applying the PPF (Expel or Terminax—I still have to decide) to the front end (bumper, hood, side fenders, mirrors, windshield, roof), and maybe later, finishing the rest as well (man, buying this car has almost left me bankrupt
) and then maybe finish the job by removing the GPF, installing a catted downpipe and ECU remapping just to harmonize everything.
EDIT: For background, I came from a 2013 RS5 with aftermarket brakes. Had full-floating rotors, aftermarket pads, stainless steel lines and high temp fluid. The brakes on Audis are one of the weak links. I regularly managed to fade the stock setup. Took a couple of tries with aftermarket pads to get it mostly where I liked the normal driving manners and where they wouldn't fade on me most of the time when driving hard. Still managed to fade them occasionally. On the other hand, I've never faded the AMG brakes, even the stock setup. I'm still using OE pads, OE lines and OE fluid, just full-floating rotors. AMG brakes are pretty outstanding and most complaints come from people who mostly daily drive their cars complaining about brake dust and noise.
Def do the FULL car PPF in Xpel Stealth - you will breath MUCH easier. One cannot really put a price on Peace of Mind.
Can you do me a favor and take a photo of the Date of Manufacture plaque on the door sill? (please crop out your VIN, and/or send as a private message if so desired)
Random thoughts:
) and then maybe finish the job by removing the GPF, installing a catted downpipe and ECU remapping just to harmonize everything.https://cimg6.ibsrv.net/gimg/www.mbw...6d84bc1b06.jpg
https://cimg7.ibsrv.net/gimg/www.mbw...5299e760ec.jpg
I think the reason is that even though I am 6'3" I never extend these, Mercedes or BMW. Had to look at my old pics to confirm.
I hope you opened it up on the autobahn. Not a lot of places you can go 200mph and not end up in jail
Enjoy and take more exterior/interior pics!
@superswiss thanks for the advice, I’ll definitely break in the brakes properly—it won’t be hard
, especially since the GTR will be used almost exclusively for spirited driving in the mountains and a few track days! After that, if I’m still not satisfied, I’ll switch to DS 2500 pads and maybe braided lines (right now the braking feels a bit spongy and lacks initial bite; it’s definitely not the brake fluid, since it was recently changed and the tester shows water content below 0.8%...)@MBNRG I didn't notice the plaque you're talking about, but I'll take a picture and post it here
In the meantime, here are two other minor issues I've noticed, though they're a bit annoying:
- I realised that it’s impossible to leave the car in neutral (given the limited space in my garage, it would be handy to move it forward or backward without having to start it every time, just like I do with the TT-RS); as soon as the ignition is turned off, it immediately shifts into P, and there’s no way to put it back into N without starting it again
- (Okay, this is really silly, I know) if you want to leave the included battery charger connected, you have to leave the hood partially open, because closing it causes the positive terminal clamp to interfere with the hood itself (due to the shape of the positive terminal, I’d say the clamp can’t be positioned any other way than vertically).
Regarding the transmission, that’s not something I’ve ever considered. These transmissions are fully electronic. There’s no mechanical connection to the gear selector anymore. In the past before engine start/stop buttons, you couldn’t even remove the key from the ignition unless the transmission was in P.
As for the battery charger, I could be wrong, but I thought the GT R has a 12V socket in the trunk that remains connected with ignition off, so you can plug in the battery charger there instead of using clamps. But yes, if you use the clamps, you have to leave the hood partially open. I leave it resting on the latch which at least in my C63 is enough of a gap and room for the clamp.
Edit: I couldn't find a better image https://i.ytimg.com/vi/zVxI-ZjF7r4/hq720.jpg
As for charging the battery, however, I’ve found conflicting information: the included charger comes with both clamps and a cigarette lighter connector, but the charger’s instructions explicitly state that the cigarette lighter connector should only be used if there is a dedicated socket in the engine compartment; if there isn’t one (as is the case with the GTR), it must not be connected to the cigarette lighter socket in the passenger compartment (the only one of this type in the GTR is indeed in the passenger compartment and not in the engine compartment); on the other hand, the owner’s manual states that the charger can be connected to the cigarette lighter socket in the trunk (pic 2), but then another section of the same manual specifies that the charger must be connected exclusively to the dedicated terminals located in the engine compartment (pic 3)...
when in doubt, I believe the latter solution is the safest; what do you think?
no eyelets in Mercedes branded charger, only clamps and cigarette socket...
As for parking without the e-brake on, IIRC, you just need to stop, put gear selector in N, turn off ignition, and pull the (P) handle on the underside of the dash to the left of the steering wheel. I've done it when I'm at the track.
As for the option of leaving the car in neutral, I will try what you suggested, having that possibility would definitely come in handy
It’s like devices that have charge limits to maintain battery longevity. For example I use my laptop mostly as a desktop, so it’s always plugged in. It has two batteries and the charge limit setting keeps them at 50% or around there. I see them drop a few percent before it trickle chargers it back to 50%. The batteries still show around 95% capacity and the laptop is now about 6 years old.
I also use the 80% charge limit on my iPhone. It’s enough for a typical day and when I use it in the car for CarPlay, this ensures that it doesn’t get pegged at 100% for long periods.
