Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz.
Removing old star and letters from trunk lid
Old Mar 1, 2007 | 01:41 PM
crimson's Avatar
1998 C230
I have a '98 C230 and have purchased replacements stars and letters. It looks like the star and letters on the trunk lid are are glued on.... Has anyone removed these successfully and has any tips to share??
Old Mar 1, 2007 | 03:08 PM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
I have seen dental floss used, waxed of course.
Old Mar 1, 2007 | 03:12 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
+1 - hit it with a hair dryer 1st to heat the glue up.
Old Mar 1, 2007 | 03:14 PM
Greg@DI's Avatar
You can take some floss or fishing line and gently slide it behind the letters/#s. If you're having trouble getting the fishing line to take them off smoothly try heating up the glue with a blow dryer. After you're done I'd recommend wiping down the area with some rubbing alcohol (50/50 mix of water and Isopropyl Alcohol). This will help remove the old glue/residue and ensure a clean surface to apply the new letters. If you really want the surface perfectly prepped I'd also recommend polishing the surface. If you polish the surface you'll help buff out any sun fade, oxidation or other discoloration between the faded clear coat and the preserved clear coat behind the letters/#s. Just make sure the polish has some cutting power like the Menzerna Final Polish II, SSR 1.0, 3M Fine Cut, Scratch X, etc.
Greg @ Detailed Image
Old Mar 1, 2007 | 03:17 PM
Greg@DI's Avatar
You are right on with the floss, it'll definitely work well. Just don't wax the area after if you're applying new letters. If you're just removing some you should wax or seal the paint after.
Old Mar 2, 2007 | 12:34 PM
crimson's Avatar
1998 C230
This is great info... I can see the old letters/numbers coming off like butter! One nagging question though.... if I get the old letter/numbers/star off the trunk lid and clean it up so well it looks like new, how will I know where to put the new letters/numbers/star so they are in the right spot?? I would hate to end up with the new shiny bits crooked and misaligned!!
Old Mar 2, 2007 | 01:00 PM
Greg@DI's Avatar
Good question. This would be my idea, but this is coming just off the top of my head. Someone with an art/design background may have a more exacting method. First off take a few pictures of the current placement. Make sure the camera is relatively level and that some pictures have the taillight and top of the trunk for reference points. You can also do some quick measurements to see where the letters should go, spacing between them etc. After removing the letters/#s I'd use a ruler or a piece of string/tape to create a flat edge to help make sure you apply them straight. Hope this helps and it comes out great!
Old Mar 2, 2007 | 01:03 PM
C43AMG's Avatar
Veteran: Army
Or a Laser Level. Good ideas Greg.
Old Mar 2, 2007 | 03:28 PM
Greg@DI's Avatar
Laser Level.... Brilliant! That would be another very logical choice too and probably more accurate.
