best way to wash under the hood
You cover the alternator put a plastic bag over the cold air intake.
Spray it down with gunk foamy engine brite,let sit per directions and hose off.
Then you start the engine after removing coverings.
Watch the decals on the ecu they will blow off if to much water pressure is focused on them.The m112 and m113 are nearly water proof. CCoils are sealed and unlike the m119 you need not fret about water in the spark plug recesses.
One item to be cautious about, do not apply any engine cleaner to any stickers under the hood, it will dissolve the adhesive and makes them come off.
