What Pads to buy for Porter Cable 7336sp?
Any help would be appreciated, thanks!
(I have Meguiars, Lake county pads and Sonus Pads)
The Sonus pad kit has everything you need. Contoured backing plate, Orange Compounding pad,Polishing pad, Finishing pad and wax or sealant pad. Plus you get two micro fiber bonnets for wax Sealant applications or final buffing.
Alos the Sonus SFX polishes are great to use with these pads!!
The last picture were the foam is split next to the velcro that is a Lake County pad. The Sonus pads DO NOT Split, Thats why I love the Sonus pads!!
But they are kind of pricy for the kit. Is there another pad kit out there recommened but a little cheaper?
If you already have a backing plate they would do.
I recommended the Sonus DAS pads because the kit comes with the backing plate.
You can read all about them here:
http://www.properautocare.com/mafopaloatla.html
This is a link of the various 6" pads and accesories:
http://www.properautocare.com/hi612infopaa.html
Don't forget to read the tips here:
http://www.properautocare.com/noname.html
I bought some Sonus pads as well, just have not had the chance to try them out yet.
I'm wondering if buffing off Zaino or normal wax with a motorized unit would "take off too much" of the Zaino vs. just using a towel to buff.
It seems like it would sure take a lot of arm work out of a good Zaino application...
Personally however, I would remove Zaino by hand. It's just eaiser in the long run.
Is there something about using the buffer for buffing that I don't know about that makes it less useful than I'm imagining?
~One man’s opinion / observations
Both these companies (LC and Sonus) use a European (German) foam and both have had problems with the Velcro backing adhesive and the foam splitting due to the size of the foam ‘backing’ (now solved)
~Hope this helps~
Knowledge unshared is experience wasted [each one / teach one]
justadumbarchitect / so I question everything/ JonM
Now I just have to get a heater for my garage.
Thanks for the tips fellas.
