CDI Fuel Filter Change
Old Sep 12, 2006 | 08:31 PM
JRGD4L's Avatar
2005 E320 CDI
Any other CDI owners change their own fuel filter ? If so, any recommended procedures ? I do my own oil changes and want to stay on top of the fuel filter more often than every 26K especially during the ULSD introduction. Many diesel pundits indicate ULSD will cause some older contaminates to break loose in pipelines, storage tanks, delivery systems ect.
Old Sep 13, 2006 | 05:04 PM
lkchris's Avatar
'10 CL550, '12 GL550
ULSD fears are all totally unfounded.
The fuel IS cleaner.
It is not A cleaner.
Old Sep 13, 2006 | 08:42 PM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Your car is only 2 years old. I doubt it has much, if any, contaminates in the tank.
Old Sep 14, 2006 | 10:18 PM
emanon's Avatar
05 E320 CDI
At 32GPH, I put a lot more fuel through the filter on my boat that I do in the CDI. Even so, it is amazing how dirty the filters are after a year. All you need to do is get one load of bad fuel and the critters will be hanging out in your tank.
Old Sep 18, 2006 | 02:22 PM
dpath's Avatar
2011 E350 Bluetec
I recently replaced the canister fuel filter on my 05 cdi. It's located on top of the engine, underneath the engine cover. You will need a torx socket to remove it and will need to replace the (two) fuel line clamps. The center-mounted bleed mechanism/sensor will need to be re-fitted to the new filter (which should include the two o-rings needed). After installing the new filter, bleed fuel from the bleed screw by attaching it to a hose and turning the key to its run (not start) position. It's a fairly easy job. I've heard that there's another fuel filter on the car but I'm not sure of its location. Let me know if you have any questions.
Old Sep 20, 2006 | 12:33 PM
lkchris's Avatar
Service/Repair CD for W211 is now available from MBUSA.
Contains fiter change procedure.
Old Sep 20, 2006 | 02:21 PM
JRGD4L's Avatar
2005 E320 CDI
Thanks everyone for the replies especially dpath. The procedure you outlined is very helpful. I really do enjoy doing some of my own maintenance on this vehicle. Not only do I save the bucks but am always amazed how well the car is engineered. Just hit 65,000 miles on the 2005 CDI and could not be happier with the vehicle. It still drives like new.
Old Dec 3, 2013 | 07:20 PM
Mitcheeew's Avatar
2015 ML 350 4 Matic 2012 E 350 4 matic Wagon
secondary fuel filter location 06 cdi ?
I've seen & now have replaced engine compartment fuel filter & am having a "where's waldo" moment trying to locate second filter (which looks similar to otjher one-where I was expecting the typical clear in-line one as on my 96. Any ideas ? I'm about to go into the trunk since I'll replace the main battery & was wondering.....
Old Jan 11, 2014 | 09:22 AM
edwinwalke's Avatar
2006 E320CDI
kind of hard to find something that does not exist. 05/06 E320CDI only has the one filter that needs to be serviced under the engine cover on the right as you face the car. Simple job to replace. I am using Hengst filters -- about $15-25 online -- have had no problems whatsoever.
Old Jan 24, 2014 | 10:48 PM
fixbenz's Avatar
cheaper than a benz...
there is a filter in the fuel tank a sock pick up type built into the low pressure fuel pump in the tank.... this may be the mystery filter
Old Jan 25, 2014 | 08:39 AM
edwinwalke's Avatar
2006 E320CDI
Requires no routine service.
Old Sep 10, 2014 | 02:25 PM
jackpai's Avatar
2009 E320 Bluetec
Anyone had done the fuel filter change on 09 Bluetec? At 40,000 miles, it's due to be replaced, though previous service interval said 20,000 miles. Any place to recommend for the filter and the clips? Thanks!
Old Sep 13, 2014 | 11:13 AM
MPH 350SDL's Avatar
1991 350SDL, 2006 E320CDI, 1999 F250 7.3L Crew Cab 4X4
Buy a Falcom ClickR set of pliers for the clamps. It makes life much easier with those type of clamps.
Old Dec 7, 2014 | 10:05 PM
efzauner's Avatar
2005 C240 2011 R350
I replace mine every other oil change... and I do have the quick click clip pliers... get them it is well worth it. on ebay.
