E320 CDi mod
#301
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
The first engine MOD in my 3.0 V6 will be removing the DPF filter, a very essencial MOD as it only makes dificult getting more power!!! ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
At the same time a ECU remap will be done, at first only with DPF turned off and some limiters rised up, just for start.
After some other intended engine MOD's, more power will come![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Here is what is going in the place of the DPF:
![](http://img217.imageshack.us/img217/2751/imag0020800x479.jpg)
#302
Nice dpf replacement!!
Where did you get that from as it doesn't look fabricated?
How is your wife's w203? I am still looking for a intercooler like the one you have on the w203 but i can't find one. :-(
#303
The intercooler you can get many universal ones from ebay...
#304
W211 e320 CDI
I have looked around all over the net and eBay and see that the only way to remove the catalyzer from the down pipe after the turbine is apparently to remove the stock pipe and take an air chisel to the catalyzer media. Does anyone just sell an aftermarket down pipe which has nothing in it?
Is there any way to turn off EGR without doing to full re-flash right now or setting off a warning light on the dash?
I want to do several mods in a specific order and watch data streams and egt and see what difference each change makes.
BTW, the generic eBay intercooler thought is interesting, I had no idea how cheap and plentiful intercoolers were now, this is the first turbo car I have modified in a decade and a half...added to wish list.
God, it has only been 4 days without my little CDI since the GF's BMW broke again...it feels like torture to drive my NSX now...how life changes you and old age creeps up from behind!
#305
I looked at some intercoolers on the web but i am not sure what would be the biggest size that fits. And how to mount the tubes for an OEM look.
#307
S212 350cdi-4-matic `11 "AMG" // C207 350cdi ´10 "AMG"
#310
If you want it for the w211 it's not the same pipe, that one is only for w203/w209.
The w211 is different but I think there should be a version without DPF, so there must be a pipe also.
I could look for it but I can make a mistake. If you want it its better to ask for it in you MB dealer. Let them choose
#311
gutting the cat
on my 06 E320cdi i have taking evreything out from inside the cat with negative results, lost power, i have now removed and modified the cat internally 3 times to create more back pressure with very good results.
#314
2006 E320 CDI 235 hp 420 ft tq
#315
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
Secondly, are you located in the USA df8s? If so, who did you use to re-chip your computer?
#316
240: from your reasoning we should be looking at MB diesels with 5 or even 4 cylinders (likely with larger individual cylinder capacity)?
#317
my car has not been chipped yet, i am trying to get as many hp as i can before the ecu tuning, i want to tune the exhaust for better performance, and i am sure after the ecu tuning will be much better,
i should have taken some photos of the work i did to the empty cat,
directly under the inlet pipe in the cat i have welded a flat plate with a ridge in order to create back pressure yet free outing the turbo must have liked the signal from the plate creating an obstacle the power as increased by a lot, i have owned this car for two years now and i know the power, not only revs freely to over 4500 but its also very responsive from 1500 and up, before dint start pulling hard until 2200 and stopped pulling at around 3800, with some leg, i whent to a flat road last knight and tried runs 0to 100 i was getting a reading around 6.3 to 6.6, i think thats pretty good for not chipping it, this cat work is unbeliavable, i thing i have found something here.
#320
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
Micah / AF1 Rac
I had my CDI ECU remapped over in Fort Worth by a Upsolute dealer , I had run their program in a VW TDI for seven years with no problems.
But the program leaves the EGR alone and the top end is still 130mph in the CDI, but I have 34 hp and 51 ft lbs tq more now.
I have found a person in the DFW area that has a person that is remapping his TDI to run a intake and turbo that he is selling.
He is pushing around 260 hp out of his 1.9L 4cly, he told that the guy that programs the ECU for him can program any mods in.
I was at a TDI get together when I talked to him. I think I almost talked him into getting his wife a CDI.
I will find his business card with his web site and post it.
His web site is driverfire.com but it under construction so I called him one programer is on the west coast and sends him his own programs and he uploads them himself so I don't know how that will work. He did not get his wife ths CDI she got a new TDI.
He is going to call and let me know what can be done as far as the top end limiter and the EGR.
I take mine out on a track every once in a while and it would be nice to have a car that was at least as fast as my old TDI was.
#322
It will hold for few months from the beginning probably... but the trany designation is what is been programed into it. Maybe if you flash TCU you can raise that limit, I don’t know how they limit it. Mine has W5A580 designation in EPC Specs, so is rated to 580 Nm. Look some of the 7 speed on different cars and they all say 700 Nm.
#323
I will be looking into the Inmotion web site.
I did not know about the transmission needing to be reprogramed but it makes sense.
Thank You for the Info !
#324
