Kleemann Power Upgrades for your CDI or BlueTec
Former Vendor of MBWorld
W211 E500 Estate
Those of you with CDI and BlueTec diesels already know what amazing vehicles they are, with ample torque, small-car fuel economy, and Mercedes refinement to boot.
With Kleemann's available power upgrades, however, your MB diesel just got even sweeter!
Here is a breakdown of the two options for your CDI or BlueTec diesel:
Kleemann KD-Box:
-bolt-on/plug and play installation
-increases fuel pressure separately from ECU
-adds 30 hp and 80 lb-ft
The KD-Box installs inline with the OE fuel rail pressure sensor. It requires no modification of existing wiring, and is completely and easily removable if necessary.
We recommend this upgrade for most customers, due to the ease of installation/removal, and hp/tq for the buck.
![](http://www.gmpperformance.com/CFJFiles/GMP/7605.jpg)
But if you want the next level of power, and your top speed limiter removed, Kleemann does offer this:
Kleemann ECU Re-programming:
-must be removed and sent off for reflash
-removes top speed limiter
-adds 40 hp and 100 lb-ft
ECU Reflash Procedure (US Customers)- after the order is placed with us, we will contact Kleemann and send you a pre-paid shipping label. Once you remove the ECU from the vehicle, package it carefully, and place the label on the box. Then just drop it off for shipment.
Once the reflash is completed, usually within 1 business day of receipt, Kleemann will ship it back to you with the new software.
![](http://www.gmpperformance.com/CFJFiles/GMP/16477.jpg)
If you are interested in either of these upgrades, feel free to PM or ask me any questions you may have on here.
Kleemann KD-Box:
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Rail pressure rampers should never be used.
The reflash might be good depending on what is done. If more pump pressure, longer duration and advanced timing is all, look for better.
I see that you are a diesel specialist, why would the company sell this product if it could damage the engine. You called it a "rail ramper" is this a common technique ro a new technique? I want to increase the diesel engine and this seems to be a reasonably priced way to do it but not ath the expense of blowing the motor.
Its little more than the old "tiny resistor in an impressive looking box" trick. A home electronics hobbyist can make one with a basic electronics board.
I want to increase the diesel engine and this seems to be a reasonably priced way to do it but not at the expense of blowing the motor.
CLK 30cdi AMG W209, A Lang W168, Impreza Sti GC8
240D 3.0T has right. Normal ramppers just fools the ECU to use more fuel. The boostpressure and airflow remains the same and that makes the engine run wery hot.
But i haven't used Kleemann products so i can't say anything about them.
At least the remap thing sounds good.
