GLK 220 CDI in the US?
http://www.topgear.com/uk/mercedes-b...blueefficiency
In the 250 CDI state of tune, the 2,143cc turbodiesel produces 204 horsepower at 4,200rpm and 500Nm of torque between 1,600rpm and 1,800rpm. Two lower states of tune are available – a 220 CDI tuning which results in 170 horsepower between 3,200rpm and 4,800rpm and 400Nm of torque between 1,400rpm and 2,800rpm, and another 200 CDI tuning produces 136 horses between 3,000 and 4,600rpm, and 330Nm of torque between 1,600rpm and 2,800rpm.
The twin turbochargers are installed in a sequential manner, with one high pressure small turbocharger spooling up quickly for low revs and the other low pressure large turbocharger taking care of the higher engine speeds. The high pressure turbo that serves the low revs has a bypass duct to prevent it from being overloaded, and it ceases work from medium engine speeds onwards.
http://paultan.org/2008/04/11/new-me...n-turbodiesel/
The twin turbo charging translate into massive torque at low revs - something the V6 petrol GLK's does not have, and thus the GLK 220 CDI and GLK 250 CDI feels and are much faster than their figures suggest.
For the same reason - as well as good mileage - almost all GLK's sold in Europe are diesels.....
You guys from the US should look forward to diesels comming your way!
That is false information. They are a modulated 2-stage design, not sequential. And a single VNT turbo will perform equally well in the same conditions. The difference is they save about $100 per engine using two cheap turbos instead of a high quality VNT. On top of that, the turbos are ancient inefficient K-series turbos (K14 and K26) instead of a modern design.
If I read correct this is not BlueTec and is a 2010 C class.
Not quite the same engine
There is a trade off in twin turbo vs VNT-twice the turbos to replace when they fail HOWEVER they are simpler and less likely to fail due to the VNT system gumming up and sticking which is the number one reason to replace a VNT turbo...which usually happens around 100k miles or more if driven alot. Normal old school turbos usually last 150-200k miles easily enough.
