Blowing white smoke
Old Jun 14, 2013 | 06:13 PM
Greasey Bob's Avatar
2005 Mercedes E320 CDI
Blowing white smoke
My 2005 E320CDI Started right up this morning and ran great until it warmed up a bit about two miles away they it started to blow white smoke out the exhaust pipe. I turned around drove home and took my 83 sd to work.
It has no check engine light and has plenty of coolant and I think oil. I do not really have a dip stick.
It is modified with an EGR emulator. EGR block off with SS plate. No Cat innards. Has about 180k miles.
Old Jun 15, 2013 | 02:25 AM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
Gee.. I wonder why my car performed outside of the spec this morning...
Old Jun 15, 2013 | 09:27 PM
not helpful
That was not very helpful. I am selling it. And fixing the A/C on my 1983 SD.
Robert
Old Jun 17, 2013 | 09:37 PM
EGR
I highly doubt that the EGR or Coolant Level are the Problem. Seems more like a clogged injector. Which is what I am leaning towards, except that I was thinking if it did that it would have gone into limp mode or at least set off the CEL.
Old Jun 18, 2013 | 09:19 AM
RobertG's Avatar
things with and without wheels
when you say white smoke, what does it smell like?
Old Jun 18, 2013 | 11:06 PM
Raw diesel
I think it smelled like raw diesel/oil. I will try to look at it on my day off. Its been days and I have not driven it and my mind is going: it is a bad injector it is a blown head gasket. The rings are seized up....
Old Jun 19, 2013 | 04:20 PM
RobertG's Avatar
does it run like it's missing?
If it is then it maybe an injector.
Use a infrared thermometer and check temperatures at the exhaust manifold ports
Old Jun 20, 2013 | 07:33 PM
nelbur's Avatar
1997 E300D
White smoke, particularly soon after start up, sounds like incomplete combustion. I don't know your engine but I am guessing that it has glow plugs that stay on for a while after the light goes out to keep the smoke away until the engine warms up fully. Perhaps there is a problem with the glow plug circuit that keeps the preheat function from working. I would drive it until you know the engine is up to temp. and see if the smoke is still there. If it is gone, work on the glow plug preheat. If the smoke is still around I would check the injectors.
Old Jun 20, 2013 | 10:55 PM
Start up
It is good on start up it is when it warms up that it gets smoky. I am leaning towards a blown head gasket.
Old Jun 22, 2013 | 03:22 PM
Bad turbo/ Bearing
I started it up and it was rattling like it had a loose bracket on the exhaust side so I took off the air intake system and I gave the turbine a spin it spun real easy. Then I wiggled it and it moved around a lot. I pulled it out of the car this afternoon suggestions on where to get it rebuilt or purchase another one?
Old Jun 24, 2013 | 02:55 PM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
It sounds like a head gasket. It doesn't take very much liquid to cause the white smoke, and, you may not detect it for a while if you are looking at coolant level. Good luck and let us know what you find. Hopefully it will be the upper and not the lower head gasket if that proves to be the cause.
Old Jun 25, 2013 | 06:38 PM
The Turbocharger needs to be rebuild there is a localish shop in Miami, That I might take it to on my day off. Or I can mail it off to the Midwest. I think it is to far gone for a rebuild kit (about $120) Maybe I can talk to the turbo rebuilders about upgrading it to make it more powerful. I always want more power but I hate my new boss and would like to get another job so I do not want to spend to much extra money on the car.
Old Jun 16, 2014 | 02:53 PM
Squeezie's Avatar
320 clk coupe
Hi guys my petrol clk 320 is blowing out white smoke took it the the garage and had all the checks for blown gasket that was fine.had the petrol drained out and some new put in this seamed to work for two weeks. But now has started to smoke again. Can someone tell me what's wrong cheers
Old Jun 22, 2014 | 09:35 AM
andrius751's Avatar
mercedes cls 320 cdi 2005
injectors
I have same problem on cls 320cdi check injector no 1 and no 3 is overfiling
