Another 2010 ML350 Bluetec engine seized
I don't even know if I have a sludge issue; I'm afraid to find out. I know as soon as I drive it, the AdBlu tank and pump will fail, transmission cooling lines will fail, and by the time that is repaired, the timing chain will be failing again.
This is my 4th and last Mercedes. It has always had it's scheduled maintenance on time by the dealership, using MB oil. It's the worst car I've ever owned, and the worst service I've ever experienced.
The Infinity I purchased since has been flawless, and the service is golden.
Mercedes-Benz. The best or nothing. I got the nothing end of the deal.
You can do a very simple test on a piece of blotting paper ( Chromatographic paper is best). Place a drop of oil from the dipstick on the blotting paper & let it stand for a while. If it looks like 6A, B or C as the oil ages it is taking the soot etc with it so the dispersant is doing it's job. If it leaves a dark soot spot in the center like 6D but the oil spreads outside that center spot you know the oil dispersency is shot & could lead to sludging. Change it!
As I said earlier the sludging regime can be very complex but this is the absolute basics & a simple go~ no go test.
I owned MB for 25 years and many other cars. I know about oil changes.
i agree that MB quality has gone down. They are stil quiet and safe, but what is most important for Majority of people is RELIABILITY!!!
i have posted reviews from edmunds. We can see what happened to me, Krd2023, the youtube video owner who spent 20,000 dollars replacing the sludged engine.
one common factor is All these products by MB are Diesels. The last Good diesel was the 2008 CDI engine (in the USA).
excuses like changing oil every 5000 miles are mute....the Bluetec engine will Seize without warning. During those 5000 miles oil changes it can seize as the damage occurs at the surface of the metal.
finally, Mercedes by reaction to KRD2023 and others have COMPLETELY lost my Trust and many others.....The fear of Lawsuits just make their behavior even worst!!!.
our next SUV per my wife has to be different Quality company not MB.
no one can buy an Unreliable car when everyone is busy and have other issues to worry about.
AGAIN THE takeaway is NEVER Buy a Bluetec engine unless you enjoy Gambling. Gas costs more in fuel MPG but it will NOT Seize.
the Second Takeaway is MB does not Value their loyal customers by reaching out and fixing the Seizure issue.
the Third, MB needs to build RELIABLE cars. Safety, comfort, style, and tech are all Great if the CAR IS RUNNING!!!
good luck.
What I don't agree with is "excuses like changing oil every 5000 miles are mute (s/b moot)....the Bluetec engine will Seize without warning. During those 5000 miles oil changes it can seize as the damage occurs at the surface of the metal."?? There is absolutely no indication that this is true globally. Seizures reported have resulted from sludge preventing oil flow.
while im glad your insurance covered it, it DOES NOT Resolve the underlying issue of Engine Seizure.
your insurance paid 14000 to replace an engine...think about it....the seizure should never happened.
i think it is OUTRAGEOUS to worry about engine seizure with Regular oil Changes.....
we can go on and on in a circle.....Engine seizure is an issue only in Bluetec diesel by MB, their gasoline engines almost never seize unless deliberately done.
i will NEVER buy Bluetec diesel by MB. I lost 19 000, time in months, feel cheated...
i still have high oppinion of their GASOLINE cars but really only the S Class. I have one but thats it for now.
my next SUV will be a different brand not a GL Bluetec. Maybe GL gasoline, probably a different company altogether.
People endlessly conflate issues which is meaningless & thus place their heads in the sand. Yes Benz USA has treated customers poorly. No the Bluetec is not a badly designed engine. It is not prone to seizure. Any engine will seize with no lubrication.
People have every right to complain & feel hard done by due to MBUSA treatment. Throwing unfounded aspersions with zero technical basis at the engine makes little sense other than spite.
mercedes muddled the water by calling some engines with only the dpf as bluetec and cdi, eg 2009 e320 bluetech.
my used 2009 e320 bluetec had multiple oxygen sensors replaced, exhaust temp sensor cel-carbon build up, swirl motor and connectors replaced, glow plug control module replaced, turbo replaced, front wheel bearings, oil leaking now, transmission not engaging if below freezing — lots of repairs but it get 20 mpg city and 36-38 mph highway. Costly to maintain with the special motor oil and repairs. Most lastly car to maintain and repair — almost all at 80000 miles.
Some people seem to have endless crap with cars. I've had 4 Benz cars in a row now. All gasoline in fairness. First three SA built & trouble free. My (German built) CLK had a battery failure at delivery but has not had a single issue since other than a slight grittiness to the brakes that was solved by a front pad change. My late 2003 C240 had one blown stop lamp & a 5 cent weeping crush washer on the transmission sump pan drain & that is all other than standard servicing, brake pads and tyres. The old C240 is now owned by a friend & is still on it's original battery (Benz/Varta AGM ~ I warned him it has to fail soon). It recently needed a CPS ~ a pretty normal replacement as they age due to high temp location on the V6 engines. Trouble seems to follow some around on this forum.
EDIT ~ there is no indication that urea injection has any influence on the oil at all. As a US based oilco we worked with Benz on the Urea injection. We had proposed an alternate route but there is nothing wrong with the chosen Urea system. We were obviously promoting one of our additive systems that Benz knows & likes.
On June 1 I placed order for rebuild DPF (only option available). The order was scheduled to leave Germany on August 7.
Today is August 28 and even my alarming emails are not getting me ETA for the part.
The car is brick in my garage for 3 months and counting.
If we mandated 100% biodiesel and eliminated all the emissions equipment, it would solve all the problems. But the transitioning is a nightmare because biodiesel loosens build-up from petroleum-diesel and damages the fuel system, and the emissions equipment is damaged by the biodiesel because biodiesel is naturally more sooty than petro which is exacerbated by he EGR. It’s a case of policy creating its own problems.
A good running diesel burning petroleum-diesel will produce nox with little to no particulate. Nox is really only an issue in urban centres where there’s a lot of congestion. Otherwise it dissipates. One running bio will produce some particulate but no nox. Again, really only an issue in urban centres.
The soluion is going to be a political one. In the meantime consumers are bearing the brunt with engine failures and high maintenance costs.
All my diesels are fully deleted now, and I use additives to improve the quality of the fuel. Time will tell if it made a difference.
it has A Huge Warningn is placed that you need a Degree in petroleum engineering AND
Be your Mechanic AND
have Hidden Cameras in the car or SUV to Verify the DEALER is Changing Oil AND
Set aside Thousands of Dollars a Year for maintenance AND
set aside Weeks of Down time AND
Import your Diesel from SA or Europe AND
Change your very Expensive Oil Every 3000 Miles AND
Forget Your Rest or Relaxation to Spend it at Stealeriship or Indie repairing the Car or SUV AND
Have a Reliable Brand Car ( ANY but MB Bluetec) AND
Pay higher Price per gallon than Gasoline To get 4 MPG better Mileage AND
Have a Tow Truck Numbet in your Pocket When (NOT IF ) it breaks down anytime it wants AND
Believe in God so you Do NOT harm yourself or others from the Constant Misery you are in from Mercedes Diesel
If All the above Conditions met....Then go ahead and
BUY the BLUETEC you want......The best or NOTHING!!!
every statement above happened to me while owning my 2011 GL350 Bluetec. God is my witness!!!
good luck.
Also, I don't understand why we talk about Adblue being a problem. It's injected post-combustion into the exhaust. How can that be a problem with oil sludging? It may cause problems in the DPF but that's another unproven theory.
From what I learned in the past two years, diesel engines must run, long trips.
AdBlue hitter will go bad in cold climates 99.9% and 99% in all other cases ))
But unfortunately we learn things hard way
at least I did.
BTW ~ There is a lot more to diesel fuel composition than Cetane number.
At 20k miles (still under warranty), the Adblue tank/heater had to be replaced this summer. $4k CAN. That was it, I was converted.
Truck is going in after the warranty runs out in October. Adblue/DPF/EGR delete and CPU remap. Between that and my spin-on oversized oil filter & high(er) zinc Amsoil Dominator oil changes at 3k miles, I'll hopefully benefit from a long-lasting and reliable diesel. As was already mentioned, only time will tell...
