R320cdi, Engine code P2626-1 won't reset
Welcome to the happiest & most genteel Mercedes Benz forum on line.
Take no notice of the bad manners of Plutoe, . Some one took away his toys when we was a child & he has never recovered. However he does give good advice at times.
Good luck with your problem. I think a professional clean of the DPF should give less differential pressure across it. See this video https://mbworld.org/forums/diesel-fo...replace-2.html
Regards,
Old John.
If it says that the DPF is beyond regening on its own I would check the values in the computer (I don't know how but its got to be in there *might need star though) A visual inspection won't help much with a DPF I would find a cleaning company and have them test the flow rate. Another possibility since you did replace the sensor maybe your diagnostics can't reset emission related codes? That is why we always recommend to use star as we know it will work and can be had for almost nothing compared to the price of a New MB or a weekly coffee habit ($350-500).
Check this place out if I ever had a DPF problem I will try them out I have heard good things from a few different people. http://www.dpfregeneration.com/
Also lets keep the language in check.
