How do I re-set service interval
Old Oct 22, 2015 | 07:35 PM
Chrismak's Avatar
2008 Bluetec E320
Hi All,
I just did my first oil change on Wifey's car that I got Monday. Not knowing the service history I thought it would be prudent to at least get that done.
I did re set the interval on since last service. Looks like eithe the last guy hadn't serviced it in 15,000 miles or the guy didn't know how to reset the computer.
Is there a way to reset the Service C light. I'm aware of the C service from PDF on here.
Old Oct 22, 2015 | 07:49 PM
marc hanna's Avatar
2023 GLK250, 1987 560SL
If you search around the forum you will find it. I've got a pdf, but I can't attach it to this post.
Old Oct 22, 2015 | 08:09 PM
Chrismak's Avatar
2008 Bluetec E320
Thanks Marc,
Appreciate response. I probably should have done some researching before posting.
I found this for an 07, wondering if the procedure is the same across the line?
2007 MB FSS Reset:
-Switch ignition on (position one);-Outside temperature display;
-Press the trip odometer reset knob three times consecutively (Voltage display appears);-Select the Service menu with the + or –button;
-Service indicator displays items (1 –14);-Press the menu systems button until the outside temperature display appears."
Old Oct 22, 2015 | 08:13 PM
marc hanna's Avatar
I took a screen shot. Here you go:
Old Oct 22, 2015 | 08:22 PM
Chrismak's Avatar
2008 Bluetec E320
Ok I found a nice YouTube video on
Old Oct 22, 2015 | 08:25 PM
Chrismak's Avatar
2008 Bluetec E320
Thanks Marc for taking time to do that.
I have a brother up your way in North York. Think you are a bit further west.
I just picks up the Bluetec and learning the ends and outs. Coming from and still have VW Passat TDI
Thanks again.
Old Oct 22, 2015 | 09:00 PM
marc hanna's Avatar
No problem. Yes, North York is about an hour's drive East of here.
Old Oct 25, 2015 | 06:53 PM
Chrismak's Avatar
2008 Bluetec E320
Well I followed the procedure exactly as described by Marc and above video and I couldn't get the reset.
For some reason after pressing button in dash three time in succession I couldn't get the 12V screen to pop up.
Thus I couldn't advance .
So I'm wondering if there's some other setting or folder the computer is supposed to be at before I commence the reset?
Chris
Old Oct 25, 2015 | 08:41 PM
marc hanna's Avatar
For some cars you have to have it set to the mileage and others to the digital speedo.
Old Oct 26, 2015 | 07:19 PM
Chrismak's Avatar
2008 Bluetec E320
Thanks Marc, I got it. I believe it was the Temp setting.
Weird how they wouldn't all be programmed the same.
Thanks again .
Old Oct 26, 2015 | 07:25 PM
marc hanna's Avatar
No problem, I'm glad it worked out for you.
Yes, it strange. I've encountered this variance on three different cars.
