1983 300SD low compression #3? Next steps?
The motor shakes at idle, and nails loudly, but smooths right out at 1,200 rpm perfectly.
I switched out 3 known good injectors on that spot, and no change. (well, of course it wouldn't change as I show low compression).
Would a leakdown test show me what I got before I take the head off and look? How much for a shop to do that?
AGAIN, the craziest part is that it has all the power during normal driving, just that bucking at idle due to that compression. I'm NOT thinking this is fuel related due to the compression (but I WOULD if compression was ok).
Ideas?
they cause skipping,uneven running
carbon can build up on a valve if it is not closing fully and cause sealing problems so adjust and if problem returns adjust again after few hundred miles
pretty easy
However still low compression on #3. Has all the power still, just lopey at idle (rack damper bolt new and adjusted almost all the way in, as that is the only position it has the least amount of shake).
Ideas?
