2013 S350 Acceleration Problems
Old Aug 28, 2016 | 12:49 PM
Chrasmus's Avatar
2013 Mercedes S350
When I tried to accelerate my S350 going onto a highway, the RPMs would not go above approx. 1,200 and my speed only made it to 30-40 mph, even when I floored the gas pedal. I managed to pull over on the side - turned the car off - and everything was back to normal when I restarted it.
The car has 48,000 miles on it, has always been serviced by the dealer (last service three weeks ago), and has never had any problems.
Any info. re. what the problem might be would be greatly appreciated!
Thank you,
Christian
Old Aug 28, 2016 | 11:32 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Check Codes.
Old Aug 29, 2016 | 03:15 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Sounds as if the car went into limp mode then reset.
As kajtek says there should be a code .
Old Aug 29, 2016 | 10:10 AM
mbdiesel12's Avatar
2012 e350 bluetec
I have a 2012 E350 BT and had the exact same problem about 3 years ago.
The car acted exactly like yours. I stopped on the side of the road and restarted it. It ran fine after the restart. It's only happened once since I've owned the car.
I took it to the dealer at the time but there were no codes found. Apparently not all limp home problems cause a code. The restart must have rebooted one of the computers and cleared the problem without a code being retained.
Old Aug 29, 2016 | 11:15 AM
mbdiesel12's Avatar
2012 e350 bluetec
I agree that we tend to oversimplify electrical and computer problems. We have a tendency to believe that every situation results in a corresponding self-diagnosing condition. It's never that simple in the software or electronics field. If it were all we would need is an OBD scanner which quite often just diagnoses symptoms that could relate to the actual problem.
I had read about the pedal sensor issue prior to my dealer visit and specifically asked if that could be a problem. The dealers master tech said not on my model and model year. At that point I had no basis to pursue the issue further. It's been 2-3 years without another occurrence.
Old Aug 29, 2016 | 07:03 PM
Chrasmus's Avatar
2013 Mercedes S350
Update
Thank you for all the feedback!
I took my car to the dealer today, and they told me that a hose supplying air to the engine had failed - and that they were ordering a new one.
The repair is covered under warranty, and they gave me a loaner to drive until my car is fixed.
Thanks again,
Christian
Old Aug 30, 2016 | 09:14 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
Thanks again,
Christian
Similar problem with my 07 E320 bluetec a few years ago. Although I believe it was actually the ductwork supplying boost, not a hose. Anyways, it had a split in it that would only open up when the the engine was warm and I had just rung it out (as if flooring it from 50-80MPH at full throttle). Took a while to diagnose as it would only happen under that exact scenario and the split was on the bottom-side.
Old Aug 31, 2016 | 11:24 AM
kajtek1's Avatar
Good that dealers don't employ people like Plutoe.
When code don't always pinpoint the problem, they give you direction.
I had split hose on older diesel as well and code was showing too low boost pressure.
Took some leg work to determinate it was not old wastegate, but split in the intercooler hose.
Interesting that our 2008 Bluetec had couple of splits on the hose, I think due the mechanics kinking the hose during other repairs, but I never had a code.
The area was dirty from oily fumes, but no errors.
Old Aug 31, 2016 | 08:24 PM
pinebaron's Avatar
07 E320 Bluetec
Same car, same year. That is interesting; it's happened to me about four times since new. Stopping and restarting cured the problem. Can you please point me to the ductwork you had issues with.
Old Aug 31, 2016 | 09:17 PM
kajtek1's Avatar
Any leak in intercooler piping will show wet, oily spot around (thanks to engine breath pipe coming at turbo inlet)
If you keep your engine clean, you will spot it right away.
If you keep your engine filthy.... well....
Old Sep 1, 2016 | 12:21 PM
DubVBenz's Avatar
Will try to find the exact replacement part this weekend when I visit my mechanic. He mentioned the part was so cheap that Mercedes must be aware of its faulty nature.
Old Sep 5, 2016 | 12:21 PM
DubVBenz's Avatar
The hose that split on my was the ductwork from the turbo to the intercooler. The ductwork from the intercooler back to the engine was also showing fatigue. I replaced both at the same time.
Old Sep 5, 2016 | 09:30 PM
kajtek1's Avatar
I can only admire your mechanic consideration for "cheap"
The passenger side hose retails about $180 and I doubt the driver side is much cheaper.
Old Sep 13, 2016 | 07:44 AM
pinebaron's Avatar
07 E320 Bluetec
I'll take a look today. Thanks.
Old Oct 11, 2018 | 03:32 PM
JJFelock's Avatar
2013 S350, 1994 SL320
Question S350 Acceleration issues (recurring)
Now on my third iteration of the same problem for my 2013 S350 Bluetec with 70K miles. In April, the car could not get over 1500 rpm and it took many minutes for it to achieve highway speed. Took it directly to the dealer, they said it was a clogged fuel filter. Problem solved (or so I thought). July, same exact problem occurred again, went to the dealer and they replaced the fuel pump (warranty had just expired, but they covered it). Now here in October, it's doing it again. Happened one day, didn't happen for 2 days, then happened again. The dealer claims there are no fault codes detected and they can neither replicate the issue or deduce the problem. I welcome any and all ideas and suggestions. Thanks.
Time to sell? Too bad, I love the car.
Old Oct 13, 2018 | 12:30 AM
kajtek1's Avatar
Drive with bluetooth plug constantly on and observe live data on your android.
