Blocking egr
i have got a question regarding blocking the egr valve. Engine is om642.950. The exhaust pipe is dividing right behind the turbo. Thats where the egr pipe is connected. The blanking plate can be fitted over there. Another option i am thinking of is where the egr pipe after the cooling block gets connected to the accelerator valve, that is where intercooler pipe gets connected to.
Question is if there is any difference if i blank it next to the accelerator valve block and not behind the turbo? It is much easier to access it at the front of the engine.
(I know the egr has to be erased on ecu prior to banking it.)
Thanks everyone for taking time reading my question and suggestions.
Thanks a lot for your message.
https://mbworld.org/forums/diesel-fo...di-mod-16.html
its a long thread and pics a bit slow t old form hosted location but not just my car...good read if you are planning on staying stock.
I dont think there is much work to do to blank it anyway. Just cut the pipe off and make a blanking plate for that end, fit it and its done.
Possibly will copy the blueprint of this plate and put it on market for other MB owners. Worth considering.
