Need advice!!
Old Jun 12, 2018 | 02:48 AM
Dorinconstantin's Avatar
Mercedes Benz GL 320 CDI
Need advice!!
I have a 2007 GL 320 CDI with 190000 miles and after a short drive on the interstate the engine start rattling very loud,seems like something broke inside... very noisy. Stopped the car and I checked the oil level it was normal, a little white smoke came up when I opened the oil cap. I waited for about 30 min and restart the car, the same rocks crunching noise from the top of the engine, I shut it off right away. Anyone experience anything like this? Please help, thank you very much! I use a scanner and I just got some transmission codes( I believe P0717 and P0718), nothing from the engine! No check engine light on? I always change the oil on time and I replaced the belt and pulley btensiometer last summer! Any help would be greatly appreciated!
Old Jun 12, 2018 | 05:57 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Google "Black Death" and good luck
Old Jun 12, 2018 | 09:16 PM
it seems that the problem comes from inside the engine maybe a valve or a cylinder it sound metal on metal up there... just wondering if anyone had a similar problem! the car still starts and sound really badddd...
Old Jun 13, 2018 | 11:55 AM
kajtek1's Avatar
If you have what you think you have, that would mean you need new engine.
How much you can work yourself, if mechanics are not easy available?
If you have loose parts inside the engine, turning it by hand should give you a feel about something knocking inside. Beware that those timing chains don't like to be stretched on reverse, so turn the engine only 1 way.
Than you can pull glow plugs and insert one of those miniature cameras.
Old Jun 13, 2018 | 02:30 PM
Thank you very much, I will have the car towed to my house and start digging in to it! I really appreciate your time!
Old Jun 13, 2018 | 10:09 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Good place to start would be pulling the valve cover and looking for missing valve stems. Would also be worth dumping the oil and looking for sparkles (or chunks) contained therein.
Old Jun 14, 2018 | 12:10 AM
I just got the car home and tomorrow morning I will get into that! Thank you so much I will keep everyone posted! I don't have much experience and I will take it slowly step by step, so bummed I love this car is been pretty good to me drove almost 100.000miles.in 2.5 years and never left me on the road! Great diesel mileage! Changed a few things air springs front and back ,shocks, did the oil cooler seal,cleaned the intake manifolds, Crankshaft sensor, CV axles, control arms, and a few other things, I love the car and I really hope I don't have to get a new engine on... Keep you posted!
Thank you for your time,I really appreciate it since I don't have any experience with engine stuff!
Old Jun 14, 2018 | 12:56 AM
Thank you so much I will do that!
Old Jun 17, 2018 | 06:58 PM
exhaustgases's Avatar
LS400
Nice update. I guess its really bad.
Old Jun 17, 2018 | 09:01 PM
Sorry I didn't update yet I have to wait for some tools that I ordered to take the injectors off...time was really tight so far and it was raining for the past 2 days since I don't have a garage I I to work outside and so grateful for the rain, we had a lots of wildfires in Colorado!!! I appreciate everyone's advise and I will definitely keep you posted!Happ H Father's Day to all the amazing Dad's out there!
Old Jun 17, 2018 | 09:10 PM
Old Jun 20, 2018 | 02:33 AM
Update
Got to the valve cover and everything seems ok... what the next step should be? Junk Yard???
Old Jun 20, 2018 | 11:50 AM
kajtek1's Avatar
Did you check all the valve springs and visible parts?
This engine uses valve cover to hold the camshafts, so don't think you can turn the engine with them off, but now, having injectors off, you can stick one of those android snake cameras inside each hole.
GoodByeHonda's Avatar
W211 E320 Diesel OM642
Now that injectors are out, put a scope in and see. ALSO have a peak at the tensioner.
I would drain oil first and send it for a quick lab analysis.
Old Jun 20, 2018 | 07:25 PM
Old Jun 20, 2018 | 07:30 PM
Thank you so much working on getting a camera and I will definitely drain the oil! Really appreciate everyone's input!
