Help! Removed and cleaned 2 injectors now no high pressur
- bad injection pump
-bad regulator
- very leaky injectors.
Since the main issue happen after injector work, the #3 is first logic conclusion.
One more thing - I know the injectors are programmed into ECU. Have no idea what exactly programming do and I changed air filters without programming, but additional thing to check.
Replace the two you 'cleaned'. They are not servicable parts, if they are messed up, they need to be replaced and quantity coded.
The injector cleaning was undertaken after everything else from tank fuel pump to fuel rail was was checked or replaced, including engine coolant sensor, cam and crank sensors and I did an injector leak test that both #1 of passenger and driver side failed and # 3 on driver side filled bottled halfway. Surprisingly, #2(middle) passenger side had no leak yet when pulled, it had beginning of black in injector tube and was fairy dirty at nozzle.
So here I sit after a 6-8 hours under the hood trying to figure this puzzle. Again it was hard starting, but would start after the second to fifth cranking cycle and now it won't start and I can't do another leak test without it starting.
background of my ownership is only for past 15k miles and I don't know the previous history. According to car fax it was 1 owner for 90k sold to Mercedes dealer salesman and then his dealership sent it to auction after his 50k miles, where I found it.
i did waste $180 at the dealer to have a diagnosis, only to have the characters say it needed all six injectors and it would work for $4000. Nothing else was wrong with it, no DTC codes and it was running, sort of.
Im not a shop mechanic but this is my 3rd om642, and my indie has let me assist a lot on repairing them, no injectors though.
the injector series # do match the ecu, so unless I somehow mixed the front 2( #1 on passenger and driver) but yesterday I thought of that and swapped them and still no fire and no HP (3k psi).
I think that covers it. Except to say the dealer is out of the question, the cars not wort putting that much $ into it. I'll part it out with my Indy before the damn dealer ever gets my money. I only use their parts dept. what a difference in staff departments under one roof.
While typing your response came in, so let me add. The only part of the injectors I touched were the nozzles, I didn't submerge the body above the nozzle cap especially the connector end , and very careful to use sterile environment to disassemble and reassembly. I can see why the ones that failed the leak test, the tips were covered in crud.
So I’m a little more than just s diagnostic tech. In my industry I’m sort of the place of last resort for both customers and OEM’s to fix odscure problems or to failure analyze motors. I did one multi week mind **** job for KTM back in the 950cc twin cylinder days where a new motor had only 60 psi compression on one cylinder and 190 on the other. The bike was brought by KTM for impossible to carburete correctly issues..(had been to all five Texas KTM dealers) .weeks later I’d find an inlet camshaft sprocket pressed on at the wrong index closing at about 140 degrees ABDCC lol. Their payment was in full and the generous. Root cause failures are the fun ones. The call me the “the last Jedi” or “Great master” or “Yoda” which I enjoy, but it makes me feel older than my 44 years suggest. This last week I’ve been trying to prove a bike reliable with zero loss of functionality after removing a malfunctioning “tip over” switch...burned a whole tank of fuel though it on dyno, RBW bikes with cruise control are freaking brilliant on dyno...set brake for highway speed/rpm....bring up to say 17-25 bhp loading depending on aero, adjust cooling fans as needed...turn off lights and break out DSLR and tripod because if you don’t the next 1/2 hour is gonna be pretty boring and miserable in a 100F test cell lol. Drink LOTS of water, like a liter every 30 minutes above 100F.
How this relates to your issue: I suspect you have two or more bad injectors. I personally own a mechanical injection cleaning rig rated to about 10 Bar and an EFI (gasoline/ethanol/methanol/propane) cleaning rig that also flow tests and balances, spray patterns and leakage testing on up to six cylinders at a time. They may be out there but I know NOBODY with a similar setup for Common rail injectors that can test from 30 to say 2000 Bar pressure. I know nobody yet I can trust to clean common rail injectors. These are different beasts. Little 48 psi Marelli or Bosch gasoline sprayinjectors they are not. Maybe someone here knows of an American shop that can fully test and clean these specialized injectors, please let us know if this resource is out there. I also know nobody I trust here in the USA to modify or upgrade our injectors to a greater flow volume or different spray pattern. This doesn’t mean there isn’t anyone, just not anyone I have heard of from multiple sources as an awesome shop.
The parts you you refer to are what I call the firing end nozzle parts set. I tried to clean these areas on my Ford 6.0 before sucking it up and paying darn near $5600 USD at dealer for “new” injectors from Ford which as it turns out are all remains now...and 1 went bad 35 miles into 750 mile round trip towing a cargo trailer. . My attempts made ZERO difference. It is possible your Injection Pressure Regulator has failed or the Flow Control Valve or the Rail Pressure Sensor though I doubt that part as it’s readings seem accurate when your vehicle is running.
How much diagnostic computer power power do you have, at least equivalent to Star or full version of iCarSoft MBII? I wish this were easier to explain and these parts more common.
Tell me, I've got this growth on my ********* LOLOL
These were clean and I only removed them for photo but all components easily fit together with no sophisticated springs or tools needed.
Originally this is all the parts I touched
Well, I only have a OBD II bluetooth and free on-line app. So I know I should give you a moment to stop laughing, but the dealer STAR said all was well with no code, matching #s good even compression, no psi out of range, absolutely nothing but "replace all 6 injectors and that will fix it", I went after to my Indy, he's has a STAR and stood with him as we verified all as well, nothing could be determined by STAR....twice, even though the problem or its symptoms were obvious, now my Indy thinks it's fuel system related but I haven't been back to him yet to solve this, I thought I would give it a shot first starting with the leak test and identifying the 2 injectors, then I though why not try it DIY since at worst it will go to him to replace the injectors or some other fuel/starting repair. Only thing I didn't count on is it not starting now, so a tow may be coming but that's what AAA for.
Peter, took your advice, took a break this am, played 18 holes. Following several of your suggestions, go back to where I last had something right and go from there. So, pulled both left and right #1 injectors and check assembly, I took photos of the injectors parts and very very carefully reassembled. Micha, the have the black return nip's. I hope I can get the photos loaded. I definitely have fuel, but again I have no start, LP psi is 75-95 and cranking HP to 300-350 psi. Next step is to switch driver side common rail with regulator and switch the two #1 injectors in case I mixed them.
so I flipped the front 2 injectors and it made no difference, 75psi Los side, 266psi on crank, no leaks, haven't D.C. hand rail yet, need to vent with a cold beverage. GD,GD,GD,GD, THIS IS FRUSTRATING!
any suggestions on using some type of starting fluid to at least get it to fire. I have never done it eon a diesel. BTW, the glow pugs are all good, I checked with meter days ago and all are good.
The way these things work, there is actually fuel pressure used to hold them closed, then again it uses the fuel pressure to open them (there's no solenoid that could move against the pressure they use alone). So there are multiple passages/valves inside the injector that you can't service or verify in your garage.
Either send them all out for proper rebuild/testing, there are shops near me in south FL that can do it, but i'm sure you can find someone in daytona (check marine places, injectors are part of the yearly service on most big marine diesels), or replace them.
this is a fairly new to me vehicle that had 140k miles on it, so the parts I replaced, seemed good idea even if they weren't the problem. Just to have a good staring point for next 200k. I have 300k on my gl320, so again I understand this platform and I do nearly all my own repairs unless it requires a lift or the labor cost is better than my time.
