Injector return leak test, Bad injector?
I removed the injector return line and ran the vehicle for 30 seconds. Every injector returned about the same fuel except the cylinder in the passenger side rear. That was about double the fullness of the others.
Thoughts? Things I should check in the Driveline CAN?
Im leaning to replacing that injector.
Left side
Right side
I shut the car off for a few minutes after checking around and seeing that the smoke was only coming from the tailpipe and started it up again. The smoke stopped and I proceeded down the mountain without any further issues. I went directly to the dealer in Colorado Springs. They said they have seen the same problem before on occasion. They said it probably was a regen that started while coming down the mountain at closed throttle.
The car was fine by then so I proceeded on and have never had the problem again. Maybe it was a combination of altitude, regen timing, and a long period of closed throttle that did it.
Driving across the country last summer, I had my daughter driving the Benz. She's a bit more conservative than I with the go pedal, and we swapped seats after a few hundred miles of easy interstate (75mph) driving. I hit the on ramp and just before the merge, floored it. The car jumped forward like I like, but looking in the rear view mirror to make sure the BMW was well behind showed the grey smokescreen I had left behind. Oops... Sorry BMW (well, sort of anyway). Subsequent 100% power yielded less and less of a cloud of smoke, until there was nothing. I'm thinking crud builds up in the intake? EGR? somewhere and a full throttle turbo push blows it all back out the tailpipe. Haven't worried about it.
The point? Flog it every now and then. Drive happy.
There is no throttle. Just the addition of fuel.
After getting the engine hot, it was really easy to take out and a cork is a nice plug while cleaning.
After replacing the injector I repeated the test, The far injector was 3" the middle 3.25" and the front was now 4".
This is a cheap test $2 bucks in hose, that is worth doing when you are changing air filters or fuel filters. To remove the return lines just pull up on the round clips.
No, it adapted over time.
No, i replaced the orings on top of the injectors. Everything else doesnt have a seal
I have.
