Trans slips after service
Old Oct 5, 2018 | 10:14 PM
dsvw's Avatar
1983 Mercedes 300d
Hi,
I have a 1983 300d. The trans was shifting hard so I decided to change the trans fluid and the filter. The car only has 66,000 miles on it, and I believe it is the first time the transmission has ever been serviced. I drained the pan but did not drain the torque converter. I changed the filter and buttoned everything up, there are no leaks.
I drained about 3 1/2 quarts of old trans fluid out of the car and ended up replacing about 4 quarts to get it just below the top line on the dipstick. I replaced it with Valvoline Dexron III / MERCON
So, the transmission no longer shifts hard. It now shifts very smoothly. It does, however, slip slightly between 2nd and 3rd gear. It won't slip if I take it very easy.
Why would this happen? I did not knock any thing off, vacuum lines, etc...My research tells me that the fluid type is what is recommended. I did not put synthetic fluid in the car because I don't think it was ever changed. I did not change torque converter fluid because I read it is better to leave that alone.
It is a very low mileage trans. It shifts much better now, no clunking. Just the slip between 2nd and 3rd.
Any thoughts why it now slips?
Thanks in advance.
Old Oct 6, 2018 | 10:48 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
You changed heavy ATF with lighter ATF.
That makes for smoother shifting, but also more slippage on gear changing.
That is adjustable by valve on bottom of the transmission. I did it long years ago, so don't remember details, but fellow W123 owners should give you update.
Disconnecting vacuum line from transmission would make for abrupt shifting.
Old Oct 6, 2018 | 02:21 PM
dsvw's Avatar
1983 Mercedes 300d
I just returned from a 75 mile drive and it is no longer slipping. A little noisy clunk from 2nd to 3rd gear but much better and no slipping at all. I did not drain the torque converter so I am thinking that the news fluid mixed with the old and it's fixed the issue?
Old Oct 6, 2018 | 02:57 PM
kajtek1's Avatar
More likely you had air bubble in the system.
Good idea to recheck the level.
Old Oct 7, 2018 | 01:54 PM
Micah / AF1 Rac's Avatar
W211 e320 CDI
I’m also of the mind it finally purged air trapped in converter and other locations, recheck levels hot and cold now.
Old Oct 7, 2018 | 10:01 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
If you really think it was the first time fresh fluid has entered the system since it was new, it would be worth dumping another round of fluid. IMHO.
Old Oct 7, 2018 | 11:13 PM
W211 e320 CDI
Agreed
Old Oct 10, 2018 | 03:41 PM
dsvw's Avatar
1983 Mercedes 300d
Must have been air. After a few hours of driving all is good now. Thanks.
Old Oct 25, 2018 | 12:29 PM
ot1's Avatar
ot1
2006 E320 CDI
Originally Posted by Micah / AF1 Rac
Agreed
i thought that vintage had a converter drain plug.
Old Oct 26, 2018 | 02:42 AM
mb crank's Avatar
ml270 cdi w163
The bearing collapsed in my 123 's converter and sent metal sludge through the system blocking the valve body, caused all sorts of problems
