Help! 2010 R350 Bluetec (Turbo Issue?)
Basically the noise you you are hearing and the case blowing oil may be two separate issues. Personally I’m more comfortable buying a 200k 642 than a 60k mile 642. At least you know one is put together right. The urea injected engines seem to have the worst issues, 07-09 I think are “basically” ok.
Would that make you thinking?
Did they remove bumper for painting? If so, they might mess up intercooler hoses. Those hoses connect using snap-on rings and small careless will have them blown away.
You should read more about those OM642 engines. At your mileage the engine might be due for intake flaps cleaning and oil leak might be common oil cooler seals.
So look for disconnected charging hoses, wash the engine and observe for where the oil is coming from.
i would chase down boost leak and do compression and leak down, best to KNOW whether or not there is any serious issue than not. Excessive crankcase pressure usually only comes from blowby though I have seen clogged cats/DPF back feed engine cases via exhaust guide seals I guess?
Mercedes cars sold in California and Mercedes diesels are different animals. From what I remember, the last MB diesel sold new in CA was in 1993, so your Bluetec in not California car?
I can understand that with small number of such customers and complexity of Bluetec, shop owners don't want to touch them.
My late friend had European car shop in Pasadena and he had bachelor's degree in mathematics. Still even decade ago he was attending at least annual seminars to learn new technology. How many indies want to do that?
Coming back to the issue, what the body shop says about blown hoses possibility?
