Injector Line fittings
Old Jan 30, 2019 | 05:17 PM
shvlhead78's Avatar
98 e300td .2003 f350 powerstroke,2014 Chevy Cruze 2.0 Diesel
Trying to find out if there are any seals on the injector lines were they connect to the fuel block next to the engine
Or is it a compression fitting a couple are weeping a bit.
Old Jan 30, 2019 | 05:19 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Compression fitting. Take them apart, observe for scratches, clean very well and reassemble. I like to finger-tight them, then wiggle a bit to make sure it sits where suppose to and then torque.
Last resort can be Teflon dope from Home Depot.
Old Jan 31, 2019 | 08:48 AM
shvlhead78's Avatar
Thanks for your reply. I assume you should take off intake to do this repair for easiest access,
also can you tell me what is wrench size is needed, and if i take manifold off is a new gasket recommended.
Old Jan 31, 2019 | 10:30 AM
Micah / AF1 Rac's Avatar
W211 e320 CDI
Absolutely yes on new gasket....if it’s off remove flapper plates and clean that gunk out! I’d get new gaskets for “up” pipe too, little triangle gaskets.
Old Jan 31, 2019 | 11:29 AM
kajtek1's Avatar
You did not say what engine is it, but all diesels I had have injectors easy reachable once you take the covers off.
I see if the forum will allow me to attach picture of OM642 engine.
Nope, the pictures downloaded, but did not attach, getting lost in forum infinity.
Old Feb 1, 2019 | 06:54 AM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Took me awhile to figure it out, goes like this ;
File Type: docx
Old Feb 1, 2019 | 07:01 AM
When Photobucket pulled their hostage-taking move 2-1/2 years ago, I was too pissed to give them a dime. Whereas if they'd been reasonable, I'd have gladly thrown them $20-$30 a year for their service.
A year later, a gentleman on a forum showed me how to post pics without PB. Couldn't believe how easy it was.
Old Feb 1, 2019 | 09:06 AM
shvlhead78's Avatar
Any part number for the up pipe gaskets.
Engine is a 6 cylinder diesel in a 1998 e300td
Old Feb 1, 2019 | 09:25 AM
W211 e320 CDI
Mine is newer but I can see if bags of spares at work still have part numbers for my OM648, good chance they are the same honestly
Old Feb 1, 2019 | 11:21 AM
kajtek1's Avatar
It was, but for some time the forum will not take my pictures.
All the download goes per the manual, I see the picture loading and showing on attachment page, but then when I click "Upload" it all vanish.
Coming to original poster, the engine is OM606 and you can find parts catalog on https://www.ilcats.ru/mercedes/
Old Feb 1, 2019 | 04:54 PM
shvlhead78's Avatar
Kajtek1 the link is a page in Russian no info.
Old Feb 1, 2019 | 05:21 PM
kajtek1's Avatar
Open the page an in right hand upper corner you will notice British flag.
That will switch the page to English English
Enter your VIN and than you can scroll EPC for exact fit for your car.
Old Feb 1, 2019 | 08:40 PM
W211 e320 CDI
NICE! Especially since I forgot to check my spares bin at work today.
i got mine from ID Parts btw.
Old Feb 2, 2019 | 03:23 PM
shvlhead78's Avatar
So i tighten injector fittings down today but in doing so a fuel line said good bye Have a set on there way
plastic ones of course all look like they are original 241,000 miles to date. So will replace them all
So whats the secret if any to get the air out of the lines which seem to be a common issue on this repair.
Old Feb 2, 2019 | 03:48 PM
W211 e320 CDI
If anything like my tractor I just loosen connections and crank for say 30 seconds, tighten and it fires right up. My kid has run it out of diesel enough times now it’s a 10 minute job and THE ONLY way it will start again lol
Old Feb 2, 2019 | 06:24 PM
kajtek1's Avatar
The 606 engine has a maze of plastic tubings, where not only orings, but also plastic seats age and then you have oring on the back of SOV and then on prefilter.
Once you get it all replaced and do a good job, you should not see air in fuel .... although at 20 years the hoses between IP and firewall might be aged.
