05 E320 CDI Oil Leak Around Valve Cover
Before I pull the injectors (if I do, thinking I should replace the nozzles at that time) and do a valve cover gasket, I wanted to see if anyone else had this problem? Looking at the valve cover seal kit, there doesn't seem to be any gasket around the bolts (just perimeter of cover and injectors), so I'm skeptical this would fix that oil getting pushed up at the bolt.
Thought maybe it's too much pressure in there, pushing oil up... not breathing properly under there?
Out of town, but will post photos when I return... as well as whatever the solution is here if I can figure this out.
It's a 2005 with about 160K miles. Bought the car around 110K. Replaced a couple injector seals, but that's the only things I've touched around the valve cover.
The middle photo is along the side, and there’s so little (tho more than pictures in other spots along side), it’s making me think it’s old oil/junk from when I took care of the early signs of black death.
Wash the engine and recheck after 500 miles.
Mike
Anyway, what the pictures show is what I call "sweating". Not a mechanical problem at all, but cosmetic one.
Taking valve cover out for resealing is pretty big job on this engine, so unless you want to do other jobs, I would not rush to this one.
Also in the past I had good results sealing the sweating with polyurethane caulk, what might be another non-cosmetic option.
