Block Heater Location? - 2016 E250 OM651 engine
So my dealer has confirmed that my 2016 E250 Bluetec (sold in Canada) does have a factory installed block heater. I have looked at the pics and other details including the block heater cord set per This MBWorld Post . The details in this post are for an ML or GL with OM642 engine. Even though the dealer has confirmed for me that the cord set p/n for my E250 is BQ-602-0611, which is the same as in the previously mentioned post, I want to validate with my vehicle, so I popped my hood and was struggling to find the block heater location. Does anyone with an E250 have a pic or good description of the location. I am assuming on the block near the front around one of the rad hose connections.
My dealer parts guy also did send me this pic below, claiming it is all they had, and it seems to suggest it may be an in rad hose heater?
Mini plug inlet cable below (from Defa cord set MB p/n BQ602061)
Those engines have very nice access to everything, so it should not be a problem to check for cable there.
Do you park outside? I heard those engine start in sub-freezing temperatures just fine. Not me, as winter for me is 40F, but I chat on Polish forum, where owners park on the street, so no power available and they just start.
Cabin heating is slow, but lot of European models are equipped with webasto, what for some reasons is not making to America.
A little more restrictive access on the e250 I would say, vs the GLK, at least from some of the pics I have seen, but should be manageable as a DIY by moving the air duct aside to gain access. I do park outside sometimes, and my interest in the heater is not so much for ensuring it starts, but for giving the engine a bit of a pre-heat on colder days to allow faster warm up -- it is just better for the engine over the long haul.
I was just looking those up as we are thinking of maybe taking our Airstream up north this winter (from FL to MN). Granted, my question was going to go along the lines of if I put in a block heater, can the rear of the RV power it...(Mercedes 2500 chasis). Plus, where on earth does it install.....
Suppose to be relatively easy.
I also watched youtube channel by Alaskan guy driving his home-made camper on Ford truck.
In very cold winter, even antigell and Webasto heater were not enough to keep his fuel in liquid state and he had to go to heated garage to start the engine again.
For the rest of the trip he kept his engine running 8 days without shutting off.
