MB bluetec lawsuit in USA
Just like the slow approval process we had to have patience...it will work out imho.
The AEM don't cover injectors, when warranty is not valid unless you complete AEM.
So to my understanding the SA show good will.
FWIW, I attached the notice for the X166 (GL class) several posts above and it very specifically covers the injectors and andedave’s truck has had the AEM completed.
So any existing conditions are legally not warranted.
FWIW, I took a look at my AEM paperwork and it looks like the first thing they did was connect the scanner for a quick test before starting the work. If your truck was showing errors when they checked it out then that would be a problem, I assume.
The good news is that's all they found, IMHO.
No AEM, no warranty.
I had similar situation with my Sprinter where 1 dealer wanted $3800 for fixing exhaust leak. I took it to other dealer in the area and they performed AEM without hassle and later on I bought new exhaust flex for $170 and had it welded for $90.
My labor for removal.
In my case it was tricky becouse PO installed cheaper flex, who failed and I restored it to original flex.
