MB bluetec lawsuit in USA
Old Sep 16, 2020 | 10:36 AM
  #151
ccww's Avatar
2015 E250 Bluetec
There is no double dipping. If a previous owner makes a claim then their award is deducted from the current owner’s award.
I wonder under what circumstances previous owners can make a claim. As they don’t own the car and won’t suffer the modifications I don’t see how they’re deserving of any compensation. Maybe if they sold the car after the settlement announcement?
Old Sep 16, 2020 | 12:10 PM
  #152
berti_00's Avatar
2016 Cls63s AMG
i've had 3 bluetecs that i had and sold. i am going to try and see if i can make some sort of claim
Old Sep 16, 2020 | 02:45 PM
  #153
sak335's Avatar
2012 GL 350
So guys, help me with a strategy. I bought a 2012 GL 350 back in 2013 from the original owner. I still own the car, but earlier this year I brought it with me to Finland. I still have a US address since this is a temporary move (3 years), but I have to believe that when I registered the car here, that they let PA (at the least) and perhaps DOT, that the car was exported. I assume that I can still get some money, but is installing this new hardware required to get the check?
Old Sep 16, 2020 | 03:04 PM
  #154
ccww's Avatar
2015 E250 Bluetec
I don’t think you’ll get anything without the car being modified on US soil. Perhaps if you come back before the deadline.
Old Sep 21, 2020 | 06:16 PM
  #155
BenjaminPQ's Avatar
Honda CRV
How to proceed with repairs?
Dealer says I need both NOx sensors replaced at a cost of around $1500. Should I wait and see if I can get them replaced under a new warranty as a result of the settlement?
What damage may result from letting the check engine light remain on?
Also, I plan on doing the delete eventually. I suppose I could do it now but I’m thinking I should keep it stock until the scandal blows over. In the mean time I’m going to change the oil every 3000 miles to keep it from sludging.
Old Sep 21, 2020 | 06:25 PM
  #156
Etienne Lau's Avatar
Ml350 bluetec
I drove my 2014 with dead box sensor for nearly 5000 miles. My only issue was DEF fluid after refill would not reset. So my suggestion keep the DEF refilled every 5000 miles or less.
Old Sep 24, 2020 | 02:03 PM
  #157
mellonc's Avatar
E250 Diesel
just wondering.... why do you need to change your oil every 3000 miles?
Old Sep 24, 2020 | 02:13 PM
  #158
BenjaminPQ's Avatar
Honda CRV
From what I’ve read, the EGR dirties the oil which leads to the known sludge issue that will eventually kill the engine.
Old Sep 24, 2020 | 03:44 PM
  #159
Ml350 bluetec
Depending on who you talk to and read about on the internet......some where by 3000 miles, while others have no problem running the 10,000 miles. But then it also depends on what type of driving one is doing. If it's all stop and go city driving, I would be changing it at 3000-5000. But if it was all highway miles the 10,000 is fine. Just depends. But I send my oil off and have it tested, other's here will swear up and down they know better than oil samples and that 3000 miles is the hard line.
Old Sep 24, 2020 | 03:47 PM
  #160
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
It is not the EGR but blowby is the reason why the oil is dirty and causing sludge. EGR will clog your intake manifold.
Old Sep 24, 2020 | 03:52 PM
  #161
BenjaminPQ's Avatar
Honda CRV
In what system does this blowby occur?
Old Sep 24, 2020 | 03:57 PM
  #162
artim808's Avatar
Blowby is leakage of combustion gases between a piston and the cylinder wall into the crankcase
Old Sep 24, 2020 | 04:00 PM
  #163
BenjaminPQ's Avatar
Honda CRV
Right but would the EGR compound the problem by introducing even more soot?
Old Sep 24, 2020 | 04:07 PM
  #164
artim808's Avatar
From my experience not really. I tried to delete EGR, then change oil and the oil was dark black after just few miles...
Old Sep 24, 2020 | 04:26 PM
  #165
BenjaminPQ's Avatar
Honda CRV
Certainly removing the EGR wouldn’t make it worse.
Old Sep 24, 2020 | 04:59 PM
  #166
artim808's Avatar
That’s true. Removing EGR definitely help the engine breathe better and keep the intake manifold clean.
Old Sep 25, 2020 | 04:00 PM
  #167
mfab's Avatar
E250 GLE300d
Typical of ANY diesel. What does this have to do with the EGR?
Old Sep 25, 2020 | 04:55 PM
  #168
artim808's Avatar
You’re right. Lawsuit has nothing to do with EGR. Back to the topic.
The modification will be mandatory or optional? Daimler will be installing new copper catalyst. Is this additional to DPF? Does it mean that after the modification bluetec car will have catalyst, DPF and SCR?
Old Sep 25, 2020 | 11:02 PM
  #169
Ml350 bluetec
There already is an existing Catalyst. This new copper catalyst is to replace that existing catalyst. SCR (Select Catalyst Reduction). The current Catalyst sits between the 2 NOX sensors. The DPF sits before the 1st NOX Sensor. The DPF has nothing to do with the lawsuit. The primary issue here is that SCR system is not functioning at all times. EPA/CARB claims that MB cheated by turning off the DEF fluid injection during certain temperature ranges and claim they were wrong to do that. However MB claims they were/allowed to do that. Note that on gasoline/petro powered vehicles, the EGR system is also turned off as well under certain temperatures as well. So not sure why there is a double standard between diesel and gasoline/petro power vehicles.
Old Sep 26, 2020 | 12:14 AM
  #170
artim808's Avatar
Thanks for explanation. Whats the difference between existing SCR and new copper SCR? They can just reprogram ECU to inject DEF fluid all the time, what's the reason for SCR replacement?
Old Oct 1, 2020 | 01:25 PM
  #171
mellonc's Avatar
E250 Diesel
I have now been contacted by Hagens Berman. Was wondering if anyone moved forward with their instructions already.
Old Oct 1, 2020 | 01:28 PM
  #172
BenjaminPQ's Avatar
Honda CRV
What were the instructions?
Did you contact them first?
Old Oct 1, 2020 | 10:42 PM
  #173
mellonc's Avatar
E250 Diesel
I submitted my info on the website about 9 months ago. it takes me to a message site where it says the final approval is coming on Jan 25, after which we are scheduled to receive written instructions via snail mail.
Old Oct 2, 2020 | 09:58 AM
  #174
xsramo's Avatar
2009 GL 320
Don't know if this link has been posted yet: https://www.epa.gov/enforcement/daim...t-faqs#lessees
I have a 2009 GL 320 and it shows that potentially the new AEM component updates will be:
  • Software Update
  • New copper catalyst, DOC, DPF
  • New NOx sensor
  • New ECU
  • New coolant thermostat (existing part A6422001915)
Expected to be available on or around November 2021, after approval.
So new DPF I guess?
Old Oct 2, 2020 | 01:25 PM
  #175
mellonc's Avatar
E250 Diesel
I wonder how slow or inefficient our cars will become after the "fix."
