OM642 mystery oil leak near fuel injectors
Old Nov 12, 2019 | 10:38 PM
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
I have mystery oil leak near fuel injectors.
The leak is not from intake. Area around injector hole seems to be dry.
Any clue where the oil is coming from? It is possible the oil is leaking through the screws? They seems to be tight.
Old Nov 13, 2019 | 12:54 AM
smiledr996s's Avatar
2008 gl320cdi
Google Black Death. Failure of injector seals. Lucky you found early. i had this happen with one much worse.
Old Nov 13, 2019 | 01:01 AM
artim808's Avatar
This is not black death. I have replaced fuel injector seals few months ago and the hole where is injector is clean and dry.
Old Nov 13, 2019 | 01:13 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
This looks like oil or diesel who could run down the valley for long distance.
Clean it up and line the area with paper towel to observe.
Old Nov 13, 2019 | 01:25 AM
artim808's Avatar
That's exactly what I did today. I put paper towel, hopefully this will help to locate the source. I'll report back in few days. The liquid was black and it looks like engine oil. I cleaned the area two weeks ago, I'm not sure whether diesel can change color to dark black in two weeks. BTW Fuel injector return line was dry and clean. No leak from there.
Old Nov 13, 2019 | 05:00 PM
Towmater's Avatar
Ml350 bluetec
Maybe oil leaking from the air box connection? There is typically a crap ton of oil vapor in the intake systems.
Old Nov 13, 2019 | 05:40 PM
artim808's Avatar
It is not from intake air box. First I thought it was from there, but everything around intake is dry. I also have oil catch can installed so oil vapor is minimal.
Old Nov 23, 2019 | 06:21 PM
artim808's Avatar
Looks like the leak is really coming from the screw. Is there a way how to fix it without removing valve cover? Maybe I can put silicone on last tvo threads on the screw right under the screw head?
Old Nov 23, 2019 | 10:32 PM
dhurley's Avatar
GL320
I would remove the bolt, clean it and the screw hole and put a little RTV on it then reassemble. Its not structural so it should be okay.
Old Nov 24, 2019 | 12:23 AM
kajtek1's Avatar
RTV would take couple days to dry, when Teflon dope will hold (or not) instantly.
Old Dec 11, 2019 | 02:48 PM
ot1's Avatar
ot1
2006 E320 CDI
teflon tape, no muss no fuss
