Oil consumption
You can do simulated compression test under "smoothness test" on modern scanner.
I see only 2 possible explanations
1. you have a leak that you don't see
2 loose turbo burns the oil.
This can also cause oil consumption by sucking oil thru the pcv hose when there is too much restriction from the filters. This GL350 was religiously serviced by the dealer and had all services performed on time. Apparently they didnt do air filters.
With basically no blowby at all but was going thru oil at about a quart to 100 or 200 mile rate. Oil usage is less with the new air filters but still quite heavy. Turbo shaft play in and out is just a few thousandths which is fine and side to side is normal. Since the dpf is clogged quite a bit I am doing a delete pipe and tune as we speak and hopefully with less pressure beteen turbo and DPF it will lessen oil usage , if it is indeed pushing oil past the turbo seal. My hopes anyway for a cure.
They are bear to replace on sedans, so those "keyboard technicians" don't want to get the fingers dirty.
Still my engine did not suck excessive oil.
FWIW....
The PCV valve and hose in the photo is the old design, was re-designed as it leak oil and the red seal would deteriorate and get sucked into the turbo charger - this is going to be very expensive.
Photo of new PCV assembly
The new PCV assembly is part number 6420101891, notice the new seal design to prevent the turbo charger from sucking in the old seal design. Also read they changed the internal diaphragm material to make it more resistant to oil and seal better. If the PCV is leaking oil it would be best to change the assembly.
Regards
Joseph
Regards
Joseph
Review the following;
"VIDEO: BLUETEC'S, The most overlooked but most important maintenance items!
The above was as posted at;
https://www.benzworld.org/threads/vi...items.2986565/
FWIW....my engine is a 2007 OM642 in a R320 CDI.
I changed the PCV to the newer design.
Joseph
https://youtu.be/5LkWszMWPqY
Joseph
There are two or three bolts {depending on the style PCV] that hold the valve on place
From the photo posted above looks like you are showing the "o" ring seal on the PVC valve.
Could you post photo / photos of the entire part you are holding in the photo?
Which vehicle are you working on?
Regards
Joseph~
