Oil cooler/seals change
Old Apr 22, 2020 | 10:41 AM
W211BT's Avatar
2007 Mercedes E320 bluetec
So there a tiny spring that is on the link between the swirl flap motor and the link rod.. I lost it. Can I just put the screw on without this? Or what else can I do besides deleting the swirl flap motor.
No spring example
Example with the spring
Old Apr 22, 2020 | 01:53 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Looks to me like rattle-preventing spring. Meaning all you risk is small rattle without it.
Than do you have ballpen with spring inside?
Old Apr 22, 2020 | 05:30 PM
GoodByeHonda's Avatar
W211 E320 Diesel OM642
Looks like pen spring will do. Here's a pic of what it looks like
Old Apr 22, 2020 | 07:35 PM
W211BT's Avatar
thank you guys but I found it and got it hooked back on! Was a pain but it’s done. Any diagrams For the engine.? Biggest mistake and regret was not being organized.
Old Apr 28, 2020 | 01:16 PM
W211BT's Avatar
Finally got everything put back.. there a little bit of smoke coming from around my turbo and my turbo is getting really hot. Is that normal?
Old Apr 28, 2020 | 01:22 PM
geniushanbiao's Avatar
2012 ML350 Bluetec, 2015 GL350 Bluetec
If the smoke stops within a minute that's nothing to worry about. Usually you will a small amount of oil or such things on the outer side of those parts during reassembly and that's the indication of it burning off. Make sure it's not leaking oil. Did you make sure you didn't touch the turbines during the operation? Also after assembly did you hand spin the turbine to make sure it spins freely with little resistance?
Old Apr 28, 2020 | 11:33 PM
  #32
W211BT's Avatar
no I did not... I could hear and feel the turbo working though. And yeah I wasn’t sure i saw a little smoke then stopped.
Old Jun 26, 2020 | 09:14 AM
  #33
Bosko Kukucka's Avatar
2012 Mercedes E350 Bluetec
Those are the swirl flap clips which attach swirl flap linkages to teh swirl flap motor arms..
Mercedes Link Rod Ball Socket
  • - SKU: MER-6420910150
  • In Stock
$3.45
$3.45
Old Jun 26, 2020 | 09:20 AM
  #34
FCPEuro.com has a Oil cooler kit which includes all haskets, orings and seals including swirl motor and linkages for this job. Form my 2012 E350 cost was about $700 but it includes swirl falp motor Trubo stand (which i returned). But it is a complete kit to do the oil cooler repair.
