Testing OM642 compression
Old Sep 23, 2021 | 11:04 AM
GoodByeHonda's Avatar
W211 E320 Diesel OM642
Can anyone suggest appropriate adapter to test engine compression? It has to be via the glow plug and that's M8x1.00.
few that I found on ebay have a short thread which makes me cautious but glow plug thread is short too so perhaps my concern of the adapter flying out and destroying the threads isn't valid.
Old Sep 23, 2021 | 11:49 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Yeah, this. As long as you don't inject any fuel into the cylinder, and get combustion, your compression pressure should be in the range of around 500 psi. The area of an 8mm fitting is around 0.08 square inches, so the actual force on the threads is roughly 40 lbs.
Old Sep 23, 2021 | 12:04 PM
So pulling the fuse off the electrical fuel pump and I'm good to go.👍 Thanks
Old Sep 23, 2021 | 12:08 PM
John CC's Avatar
Don't know. Some high pressure pumps can draw enough fuel without a transfer pump to cause trouble, Better if you can disable the injectors directly, but, then, maybe it won't crank, either.
Old Sep 23, 2021 | 12:21 PM
chassis's Avatar
2017 GLE350 4MATIC
What is the reason to check compression? What prompts the desire to check it?
Old Sep 23, 2021 | 12:38 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
You better get proper scanner for the test.
Those engines can have simulated compression test, where computer compares rpm while turning each cylinder.
Takes about a minute, once you have scanner set up.
Old Sep 23, 2021 | 02:38 PM
With this car, when the engine is cold, running MB xentry compression test suggests running compression on all cylinders. But when the engine is warm, the das crank test passes.
Old Sep 23, 2021 | 04:25 PM
kajtek1's Avatar
English please?
Old Sep 23, 2021 | 04:42 PM
Run the simulated compression test utilizing my MB xentry on a cold and warm engine. Test fails on a cold engine ( I get a difference of 22 rpms and should be under 7 if i recall correctly) and suggests I do compression on all 6 cylinders. But the car runs well when cold and warm.
Old Sep 23, 2021 | 09:00 PM
chassis's Avatar
2017 GLE350 4MATIC
Why are you going down the path of measuring compression? What is the genesis of the idea?
Old Sep 23, 2021 | 10:12 PM
Right after completing the oil cooler seals change, the car would not start. Star diagnostics begins with running the simulated compression test. Results of that test on a cold engine suggested performing compression test.
Old Sep 23, 2021 | 10:42 PM
kajtek1's Avatar
Is it 1 cylinder showing 22 rpm difference from others, or more of them?
When gauged compression test will be more accurate, it will not fix bad cylinders.
22 on 7 allowable doesn't mean the engine is bad, just has weaker cylinder.
What is mileage and history of the engine?
Old Sep 24, 2021 | 09:55 AM
John CC's Avatar
Cold compression checks are not very informative. How does it do when warm?
Old Oct 9, 2021 | 01:19 PM
have a peak at the attached images. The test was done with the engine being off for 3 days.
Old Oct 9, 2021 | 01:38 PM
chassis's Avatar
2017 GLE350 4MATIC
Interesting, thanks. Now what?
Old Oct 9, 2021 | 01:50 PM
The car runs great now. Warm or cold. But for curiosity I will check compression once I get the compression adapter. So far, this one seems to be the best imho but I'm failing to understand why the tester has to be long enough to reach the compression chamber.
Old Nov 24, 2021 | 12:34 AM
Misha_'s Avatar
2012 GL350, 2014 GLK250
Did you end up doing the compression test?
Old Nov 24, 2021 | 01:41 PM
Not yet. Car runs great. I will eventually get the adapted ...
