W164 350 bluetec 2011
Old Nov 3, 2021 | 02:40 PM
Delens's Avatar
Hello
i have a problem with my car
my fuel pump have a rattling noise at 1500 rpm.
i have p0087 and p0191 error code
i have changed fuel rail sensor and fuel pump still same insue.
can anybody help me
Old Nov 4, 2021 | 11:23 AM
B34chBum's Avatar
R320, Astro, JSW, ST4
Is continuation of this thread:
https://mbworld.org/forums/diesel-fo...re-sensor.html
To me, it sound like bad high pressure fuel pump on front of motor, or the control valve mounted to it.
Old Nov 4, 2021 | 12:21 PM
Delens's Avatar
i have changed the control valve and the fuel pump if i unplug the rail sensor the car works fine because it goes in limp mode
Old Nov 6, 2021 | 09:46 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
What's the mileage on the engine?
Even the engines are 1 milion miles rated, their fuel pumps are not.
I had failure of HP pump on I4 Bluetec at 260,000 miles on Sprinter. I took the pump apart and when the failure happen due to broken spring, the pump shows wear and I recall earlier test showing lower pressure as well.
Get Autel dongle, who will give you nice troubleshooting page for the system.
Old Nov 6, 2021 | 10:02 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Yeah, consider what it is doing: taking a low viscosity liquid and pumping it up as high as 2000 bar (about 30,000 psi).
Old Nov 6, 2021 | 10:34 AM
kajtek1's Avatar
The pump is build to pump high pressure, when it uses diesel fuel for lubrication.
We do have experienced diesel shop owner on Sprinter forum and he says the HP pump wear out happens when fuel is contaminated with water or gasoline.
My Sprinter had 2 commercial owners before I bought it and used as a shuttle locally, so I have hard time to believe such owner would do those mistakes.
Still 260k miles before pump failure on Sprinter took the amount of fuel that SUV or sedan would use on 600k miles. Can't really complain much.
Old Nov 6, 2021 | 12:58 PM
Delens's Avatar
hello
I’ve changed 2 fuel pumps still same noise
Old Nov 6, 2021 | 12:59 PM
Delens's Avatar
