OM642 Slow Start
Now when I plug in the odb tool, I get the following reading: when starting about 100-135 RPM, and pressure about 2000PSI. Now everywhere I read it said it needed about 200rpm to start correctly. I've even attached a second battery and a boosterpack to make sure there where no missing available current and the speed seems to be topped at 135-150rpm... I've called a Mercedes dealer and ask if with these numbers they tought the starter may be comming a bit weak of something, they told me that start either work or not, but don't get weak overtime. The batt voltage drop is also from 12.6 to 10.2 v when using the battery dedicated. If the batterie is 100% new, it seems for the first winter it actually improve the starting, but as soon as the battery start to slowly get less power the problem comes back.
I've hooked up the battery to an OGM battery tender now 100% of the time when resting in the driveway, this seems to have improved the starting but still slow speed but more constant, typically I get
135-135-135-130-125-115-105-100-100-100-100 and stop. I will post picture of the information from the ECU (Voltage, RPM, and FuelPressure)
As far as I can tell not getting 200rpm seems to be the likely cause of hard start, now charging system is ok, battery is ok, I am left with 2 choices that I can think of:
1 - Poor wire terminal, wire connection, or problem between the battery and the starter.
2 - Started brushes are getting worn out and thus reducing the speed/power of the start.
Is there any easy way to further diagnose the problem? I just want to check before starting to throw part at it for no good reason.
THanks,
What scanner do you have? The HT/AP200 are very good bang for a buck. When I had fuel pump failure, I found whole troubleshooting page, who did show me all the parameters involved, showing weak points in red.
I had starters burning some coils and turning slower. Rare failure, but it does happen.
Tomorrow morning on the first start I try to get a graph with no sucessful start that will show more of the information I am trying to show here.
Since I bought HT200, the MBII collects the dust.
Its only advantage is that it works independently from anything, while HT needs android and sometimes needs Internet for license checking.
Still I am using the MBII since I only have this at this time, but on a fully charged battery (hoocked up to a battery tender and on the first image its even with a 400amp boost capacitor pak. So in the best world I am not getting 120RPM on the start and below 1600psi.. Typically what I see is when I reach about 130-140rpm and about 1800psi then the engine start, but it I dont get over that 1800psi it seems the injector are not even throwing fuel in the cylinder. Now my understanding is that it should be at least close to 170rpm, I believe with the 70rpm more this would allow more pressure to build and should get a good start!
So my question still remain, if the charging side is working and the battery is getting the expected rating, what can explain the starting going from 100-110 rpm to 135-140 or even higher. I believe the cold is affecting the battery charge, and also the resistance in the engine, I have had no problem once the engine is started, it will start hot as well. Eventually it will start, its just the time it takes to start it will vary. Since I can get a bosh started for around 200$ and that our hourly rate for MB Service for check if 155/hr I am leaning to replacing the starter as a try, then perhaps have a full dealer diagnostic. But right now its very cold outside not really happy to go under the hood at -20!!!
If any other ideas that would be nice.
Thanks!
Anyhow!!! THanks for the help, and again, if you aren't seeing about 180-200 rpm when starting your diesel! Check battery and charging but if they are good there is possibility your starter has become weak! (Could be the wiring too).
Have a great one!
as you point out a new battery does Help as it increases the CCA and stops the voltage dropping as much on start, therefore allowing for a better rotation speed of the starter and starting it.
however overtime, the CCA decreases and the rotation speed decreases, making it hard to start. Strangely I found if I turn the key on and wait 15 seconds or so it does start better , but overtime that also fails.
this thread, and thank you, has given me enough confidence to try a new starter motor. I’m pretty confident now that the increase rotation speed will get the OM642 going.
My GL320 has always taken, what I believe, a little longer to start - although it hasn't gotten worse in the 8 years I have owned it. It definitely starts harder in the really cold weather - sometimes taking 2 or 3 attempts.
However, doing a couple glow cycles does help as it warms up the combustion chamber more. Dave, this is what you are doing with that "15 seconds". What I do, though, is to push the start button (without foot on the brake) to activate the glow plugs (you'll see the light). I let it go for a few seconds after it goes out, then wait 10 seconds and repeat.
I did think the issue might be also associated with low rotation speed, as I was adding the extra voltage it was definitely increasing the rotation speed and starting well. I put in a new upgraded starter motor on, (merc upgrade starters from 1.2kw to 1.7kw) .This definitely increased the rotation speed from 120rpm to 200rpm where it should, however starting still remains an issue as soon as it got a little bit cold. As soon as the cylinder chambers are warm enough, either by outside weather or have been around that day there isn’t a issue starting.
The next course of action for me is to potentially put in new glow plugs, and I already have a new OEM glow plug module. This I hope get the engine starting off the button again in all conditions as it would’ve come out of the factory.
There still is that underlying, possible fault, all the systems may have developed over time of not getting just enough voltage. My mechanic indicates there’s lots of X164 that have this cold starting issue and they think it’s to do with the length of cable between the battery and the motor.
it is worth noting that I did put an aftermarket glow plug module in the vehicle about a year ago. I did not change out the globe plugs, however it did start off the button for the first time in a long time. Only lasted a couple of months and then it went back to needing to manual glow the car and pretty much the same why everyone is indicating, giving it up to 15 seconds, and repeating when very cold.
I hope this helps anyone in the same position. it would be interesting whether, this occurs outside of the X164 , that is a design that does not have such long cable length from battery to motor.
I've wondered about the cable length, as well. Maybe it should be a thicker cable?
