Dim Right Tail lights-E320 cdi-2006
Old Nov 27, 2023 | 04:42 PM
zanderalex1's Avatar
2006 E320 CDI
2006 E320 CDI-The right rear tail lights are dim and I don't find a ground connection. What else to check that could cause this.
Old Nov 27, 2023 | 09:31 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
What you call dim?
From what I remember 2006 tails operate at 6V and only turning the fogs gives them 12V
Old Nov 28, 2023 | 08:28 AM
2006 E320 CDI
When all lights are on the right rear tail light is not as bright and should be as bright as the left tail light.
Old Nov 28, 2023 | 11:10 AM
kajtek1's Avatar
Sounds like you have fog lights activated, therefore the difference.
Old Nov 28, 2023 | 05:46 PM
2006 E320 CDI
NO, When all the lights are on in the last week were fine.
Old Nov 28, 2023 | 08:15 PM
nelbur's Avatar
1997 E300D
I think your instincts about a ground problem are good. I would find the ground to that light and make sure it is good. You might need an electrical diagram to find the ground location.
Old Nov 29, 2023 | 04:33 AM
2006 E320 CDI
An electrical diag would help tremendously.
Old Nov 30, 2023 | 12:34 PM
sand8's Avatar
05/CDI, 08/957S, 07/997-4S, 16/RRS/TD6, 23/9Y0/TSH
I thought the each tail light has 2 bulbs? May be one is blown?
Old Nov 30, 2023 | 07:56 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
I suspect if the light was dimmer that it was supposed to be you'd be getting a bulb out warning. Have you confirmed that the rear fog light is turned off? Tail (marker) lights are not that bright. The rear fog is about the same brightness as a brake light.
