Just thought I’d share a few pics. I bought an oil filter cap off of Amazon, drilled a hole in it and screwed an inexpensive 1/8” gauge in it. Glad to say no leaks. I have a 2013 with 300k plus and a 2015 with 135k. Both SUV’s oil pressure readings were the same. I took the reading with an oil temp at 195F (for the idle & 2k rpm) give or take a few degrees. For the neutral WOT the oil temp
was a little low like, 165F.
Hit idle - 21 psi
2,000 - ~70 psi
2,900 - around 110 psi (not quite up to temp yet)
