Mercedes-Benz Service - Am I getting gouged our is this normal?
This is my first Benz, previously I owned an 05 Audi S4 & 09 BMW 3series so I am not accustomed to seeing a bill when I pick up my car from service.
Just curious to hear from other Mercedes owners if this is normal/expected and if there is a more cost effective way to get the services done. (please share any and all tips/experiences, they will be MUCH appreciated)
With Internet information making it harder for anyone to make big margins on car sales, these service visits are huge money makers and help pay for the fancy dealerships. And yes, there are more affordable options. Certified independent service centers will perform the same checks for less. Or you can always just get an oil change and reset the service indicator yourself. Below is the list of checks normally performed during the B service, just so you'll know what what's not getting checked if you elect to go that last route.
Engine compartment
Visually check
- Leakage of major components
- Chafe marks, line routing, components in the event of leakage, determine cause and create estimate if necessary.
- Replace engine oil and filter
- Check and correct fluid levels
- Engine cooling system, anti-freeze and corrosion protection
- Brake system
- Windshield washer
- Power Steering System
- Top off fluid level of window washer system
- Replace dust filter
- Replace wiper blade(s) if necessary
- Check condition of poly V-belt
- Throttle linkage, check function and condition
- Check engine hood and safety catch for proper operation
- Check Battery acid level & replenish
- Check battery using "Midtronics" Tester
Function check
- Horn, headlamp flasher, hazard flashers, turn signals
- Warning/indicator lamps, illumination and interior lighting
- Exterior lighting including headlamps
- Inspect headlamp range adjustment system (does not apply to xenon headlamps)
- Replace bulbs as necessary headlamps, fog lights, and some third brake lights extra cost.
- Inspect headlamp setting, adjust to correct setting
- Windshield wipers, rear window wiper, windshield washer system
- Headlamp cleaning system
- Check seat belts for damage and correct function
- Reset FSS counter in instrument cluster
- Replace wiper blade for front/rear window
- Check body for paint damage
- Check chassis and supporting body parts for damage and corrosion
- Check level control if equipped
- Inspect wheels, rotate if necessary
- Check thickness of brake pads
- Check condition of brake discs
- Check brake pads for lining thickness front/rear
- Check condition of brake discs front and rear
- Check parking brake (function test only)
- Correct tire inflation pressure
- Inspect tires for damage and condition
- Measure tread depth
- Check play in front and rear wheel bearings
- Check condition of front axle ball joints
- Check condition of steering mechanical components
- Inspect play of tie rod and drag link joints
- Inspect rubber boots for damage or wear
- Inspect exhaust system and hangers for damage or leaks
- Check for damaged/worn drive train parts
- Check for excessive axle joint play
- Correct tire inflation pressure in spare tire
John C,
Thanks for your timely response.
QUICK PLUG: The dealership is Motor Werks in Barrington, IL. They have an outstanding service model and I would recommend them to anyone. (Mercedes-Benz, BMW, Porsche, Infiniti, Cadillac, Saab, Honda, and Land Rover)
I, for one, do all my works in the dealership. However, I do believe that the dealership is the place to go if your car is still under warranty.
One thing I don't understand is Carfax. Let say someone got into a big accident and got it fixed in a non-dealer body shop, how would the information of this repair get into Carfax?
My thoughts exactly.
Engine compartment
Visually check
- Brake system
- Windshield washer
Function check
People are strange ;-)
