Stuck in "S" Mode
problem it might take some trial and error to resolve
Are you really stuck in S or is the transmission failing to get into any of the overdrive gears?
I have also been underwhelmed with the difference between E and S generally. Seems to me the only reason to go to S would be for some type of competitive event.
BTW did they check the simple stuff first like the switch itself. As an EE who has troubleshot many electrical systems it has always amazed my how people skip the simple stuff and jump right to the more esoteric.
I lost count of how many times a loose connector, wire etc. was found only after long, tedious and expensive down time. The worst part is after they find the simple fix people usually won't admit it thereby making sure that the next incident will probably go through the same long, tedious and expensive procedure.
I'd love for it to stick in S as sometimes I forget to change it. However, that is certainly a defect if it doesn't start in E and won't let you switch.
The 550 on "S" is fun to drive when that is what you want to do, but you really need to be aware of it or you peel out of every intersection. It also gets angry when you accelerate quickly and then take the foot off the gas (it can really jerk your head around if you aren't paying attention). The wife isn't a big fan, so when it isn't in E for her, my left ear hurts.
What is it they "fixed"?
The only reason I mention this is when people post their problems and the real fix it may help others make one and only one trip to the dealer if they have a similar problem.
I am somewhat optimistic this time because the problem resurfaced sooner the first two times we had it in to be fixed. This time, it seems to be working.
Brake sensors are usually there to provide a wheel speed input to the ABS system. If the ABS system is compromised I would think you would get an error message upon start up.
According to some friends who have worked as dealer technicians in various brand car dealers they would always replace something even if the real problem was simple such as a loose wire. The factory repair standards/dealer remuneration didn't provide anything like the time it actually took to find and fix the real problem.
