Tire sizes for 8,5-8,5x19 wheels.
Hi, anyone could provide me with some more info about tire sizes. I have ordered 19 wheels which are 8,5 Front and 9,5 Rear. Just wondering which size would fit without rubbin fenders or e.t.c. Car is not lowered.
3MB's has posted valuable information.
i think front will be on level with fenders on 245. same i thought for 275 for rear.
P.S. 3MB, how do you think, will it be okay 245/35, 8.5J for +32MM offset (rear) ?
OK. Same wheels/tires as US.
1. With 9.5 et35, I would use 265. Ideally I would want 275 on 9.5, but with higher offset (and for higher horsepowered car). On E200 you do not realy want too wide tire, except for looks maybe.
2. 245 on 8.5 e32 upfront is a bit aggressive and may stick out just a bit, but should still be fine.
3. 245/35 on 8.5 et32 for rear is fine.
IMHO, above sizes are ideal for 20" wheels when one wants to use a bit more rubber to protect wheels and to feel wheel gaps to eliminate need for lowering, but can be used on 19" as well to maintain stock like diameters.
But for 19", ideal sizes are 245/35-19 and 275/30-19. However, 275 wide tire on 9.5" wide wheel with et35 will stick out passed fender for sure, hence need to use a bit higher offset wheel (if available) or 265/30-19 tire if you do not want it passed fender (btw, even with 265 on 9.5 et35 wheel/tire maybe a bit passed fender, depending on tire manufacturer).
