converting e coupe 2012 to 2014 facelift
Rating: Thread Rating: 2 votes, 5.00 average.
Old Dec 11, 2017 | 07:50 PM
  #301
KiNaKa's Avatar
A207 E250CGI
Talking
Originally Posted by Chris The Swede
Far from just codings...Alot of other unknown problems no one speaks about like all the repinning that needs to be done to conectors on SAM. Since many cables run to different spots under it. Like the canbus and lin bus for speedo as just one example. Almost No one knows this since it dont show at first. But if you dont do it Star diagnose wont even see the speedo after the change.
oh my god Chris i just saw you again in youtube.
Have been watching many of your videos but didnt know that was you.
May I know how much is the convertor module cost ?
Do you sell the Led headlamp, AMG bumpers as well ?
Old Dec 12, 2017 | 02:57 AM
  #302
Chris The Swede's Avatar
W222 S63L, ML/GLE350
I have it all..PM Me..
Old Aug 21, 2018 | 12:49 PM
  #303
Anas Hamed's Avatar
c207
C207 to w212!!
Is it c207 converted to w212 front?
Originally Posted by Camber53
conversion form facelift semi led to full led headlight
Attachment 376918
Attachment 376919
Old Aug 21, 2018 | 01:06 PM
  #304
400ixl's Avatar
E250 AMG Sport Convertible
No, w212 parts don't fit, facelift 207 parts are used.
Old Aug 21, 2018 | 03:55 PM
  #305
Anas Hamed's Avatar
c207
W212 on c207
I have c207 2014, and after i saw this german company I thought that it can be done, check this link (http://www.fxdesigncars.com/E-Coupe-w207-lift).
i don’t know how the did it, but I kinda of like it and feels looks better.
Check the photos attached and let me know if you think it’s worth it?
Old Aug 21, 2018 | 04:20 PM
  #306
Anas Hamed's Avatar
c207
Do you think the original design on c207 2014 looks better or the upgraded one, w212 2015 looks better. Which one you prefer?
Old Aug 21, 2018 | 04:42 PM
  #307
400ixl's Avatar
I am not sure what you mean. The W207 (C207 & A207) platform cars looks like the W212 platform, but does not share body panels. In fact the W207's are built on an old C class chassis. W207 comes in pre-facelift 2009-2103 and post facelift 2014-2017 when the W238 platform was released. You can convert the pre-facelift to the post facelift using W207 parts, non of the W212 parts are involved.
The aftermarket bodykit you have linked to again is for the W207 platform and will not fit any W212 cars.If you have the C207 on a 2014 it should be the facelift so that would be fine, otherwise if you have a pre-facelift you will also need to do that work to it as well to get the later headlights, tail lights etc working.
Forget about the W212 body, non of it will fit. They look alike, but that's the extent of it.
Do a search in this forum and someone did fit a similar aftermarket bodykit.
Old Aug 21, 2018 | 08:46 PM
  #308
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
Just a side note on the subject, I also have a W207 face lift but recently bought also a W213 and changed the front grill for the E43 diamond grill, and I noticed that the new platforms >2017 all share the same grill, E coupe, E sedan and CLS.
Maybe the old ones be the same, just some one that have the two models that can do some test fit :-)
Old Aug 22, 2018 | 04:42 AM
  #309
400ixl's Avatar
People have tried the W212 and W207 parts previously and reported they didn't fit. They will probably be more aligned in the latest models as they are all designed together, whereas the W207 is a bit of a step child where they took an old C class platform and made it look like an E class, hence it being a bit of a one off basket case.
Old Aug 22, 2018 | 12:40 PM
  #310
gaiex's Avatar
The new E coupe still is a C-class chassis, nothing changed, maybe just the production costs using more parts between models.
Old Mar 13, 2019 | 04:59 AM
  #311
Elie Bayram's Avatar
E coupe 2016
hey how are you?
I would like to know how did you do the conversion? by yourself? if yes did you change any of the wiring harness? and how did you program the new control units and the new SAM? Using star online?
thank you
Old Mar 26, 2019 | 10:17 PM
  #312
Dnasty's Avatar
2010 e550 coupe
This may be a bit late but i've seen the rear face lift tail lights made by a company called uro and they say they are interchangeable with the original style. Same size and plug and play conversion from the original to the newer led style. Can anyone confirm this?
Old May 7, 2019 | 02:10 PM
  #313
Sameer Sidat's Avatar
Mercedes-Benz e class coupe
E class
[QUOTE=gavrocool;5669586]In about a month i will make the change and i will post all the parts needed fo
r the change.[/QUO
Hello gavrocool did you make the changes on your e class pls tell me wht I would need to change my e class coupe it's the same year as yours
Old Jun 18, 2019 | 11:19 PM
  #314
CedesDrip's Avatar
𝒞𝟸𝟷𝟾 𝒞𝓁s 𝟻𝟻𝟶
Originally Posted by gavrocool
Today i placed my order for the whole parts on my way to 2014 model.It is very simple ,in a few days i will post the whole list of parts.
First infos:
HOOD-the same
FRONT FENDERS-the same.
At the rear we have to change the rear lamps and the SAM unit.I won't change the rear bumper for the moment.
Front:headlamps+electronic unit of the headlamps+SAM unit.
Underneath everything is the same(depending on the engine type)
Front bumper,grill,bumper grills,chrome insert on the bumper(AMG),headlamps support and some more small parts.
For me it is very easy to convert.
Feel free to ask me anything.
Hey i want to convert my e550 coupe to the 2014 so ur saying that everything is the same besides lights front and back and front fender and back bumper ? I’m like really adamant about doing so so i would really appreciate if u can walk me through on what i need done
Old Jan 12, 2021 | 04:29 PM
  #315
Manclad's Avatar
Ml 250
Tempomat and hold function
My only problem after finishing all the facelift is that my Tempomat is not working.As well the Hold function.
did you get this sorted if so what was done?
Old Feb 11, 2021 | 03:56 PM
  #316
brandonh1022's Avatar
2013 e 350 coupe
SAM unit
Either you change the SAM unit,either you can modify the old one.It is not difficult.The bumper is the problem,we need to change it.
The front is quite easy because we will change the bumper anyway.I have ordered the parts for the front.When they arrive I will post all the info.
what is a SAM unit. And how do you recode the headlights and tail lights. What program do I need to install to do it all? And is it easy to do?
Old Feb 11, 2021 | 04:31 PM
  #317
You need Star Diagnose. And Vediamo. Very advanced coding. And you dont need a new sam with a converterkit.
Old Feb 11, 2021 | 09:04 PM
  #318
2013 e 350 coupe
E class conversion
so to a person who knows nothing about any of that😂, how hard would it be? And is there some type of bundle kit I can buy that has absolutely everything in it?
Old Feb 12, 2021 | 03:35 AM
  #319
Yes there is.. Cant link to it here though because then they ban me for advertising.
Old Feb 12, 2021 | 11:56 AM
  #320
2013 e 350 coupe
ohh I see. Are you aloud to just tell me what to look up.
Old Jun 27, 2021 | 07:26 AM
  #321
Manclad's Avatar
Ml 250
Can e2
Originally Posted by xoy
For sure its possible to fix - you just have to change enough parts I
played with some different camera setups today and found one working so I can get the adaptive high beam assist to work - it works and reads traffic signs, and register the lane I am in, really cool functions. The CAN e2 from the cam to the headlamps and instrument cluster is also working so all good.
The only thing is I now need to change the windscreen to fit the cam properly, since they changed the design on the cam to only fit the new screen - not so cool at all actually.
My "hold" function works - no problem. What electronics did you change and who coded the Sam? It must be some wrong codings in either the Sam or zgw.
Does you tempomat work and only gives the fault code like mine or doesn't work at all and also a fault code??
Attachment 275930 Attachment 275929 Attachment 275931 Attachment 275934 Attachment 275933
how do I create can e2?
Old Mar 2, 2022 | 11:21 AM
  #322
Mbenz1076's Avatar
2013 Mercedes Bene E350 Coupe W207
Wiring Details
The programming is not that tricky if you have all the necessary parts.The rewiring is a bit difficult.I am now trying to avoid buying more parts by reprogramming.CAMBER may not have done a complete facelift,i mean he may have some errors on board.I do not want any errors on my car,so that i can keep my warranty.
Is there any wiring instructions for the LED conversion lights kit?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
