push start question
and how much would it cost to install both keyless entry and keyless go?
That said, ask the MB dealer if they can do it. Or scour the web for someone with experience. Or hit the aftermarket - here's one:
http://www.digitalguarddawg.com/KEYL...COMBO-PG-1.htm
You can find out if your car has Keyless Go by having a local dealer print the car's data sheet - that will list all installed options.
1. Does the car come "pre equipped" for keyless go and it is just turned off unless you pay for the option? (this is the big question)
2. If number one is correct, can I just go and get new, or reprogrammed, keys from the dealer?
3. Can the dealer easily install it if I ask (I think I can work it into the deal)?
4. Can I really just buy the $30 (estimated) button off ebay and it work?
Thanks for the help.
when you push the PTS button it looks for your valid key via the multiple antennas in the vehicle. it then authenticates the valid key and starts. those with pts can see this by looking at the fob when pressing the pts button. the keys led will light up indicating communications with the vehicle.
if it is not equipped with KG, to add it is going to be expensive and you are going to spend a pretty penny
2. See above.
3. The electronics in the E class are complex. Having a dealer or aftermarket installer fiddle with the electronic circuitry is a REALLY BAD idea.
4. Not without the supporting modules.
Look, Keyless Go is nice but not essential. If the car without Keyless Go has options you really want, buy it.
