2014 E350 Cab weird clock?
Old Oct 4, 2013 | 08:53 PM
SteveFromMN's Avatar
E350 Cab
Anyone else have the analogue clock spin?
This happens only when the top is down.
I think the sun hits it. Weird, haunted maybe.
Old Oct 4, 2013 | 09:30 PM
golfster's Avatar
Titleist
There is a TSB on the clock. Look in the 212 forum where Konigstiger is kind enough to post these for the members:
LI54.30-P-056977 AUG13 – MY2014 212, 207, 218 analog clock sporadically executes a normalization sequence, replace clock with part # 2188270070. Sunlight rays can pass through the face to the inside causing the IR sensor to detect loss of synchronization the clock then runs a normalization sequence.
Old Oct 5, 2013 | 09:48 PM
E350 Cab
Thanks I hope they don't have to take the entire dash apart to change it.
I hate having the dealer do anything to my cars.
Old Jul 5, 2014 | 10:33 AM
E350 Cab
They did mine. According to work order it took less than 15 min.
Old Dec 10, 2014 | 10:46 PM
BeachBunny's Avatar
2018 E300 Luxury - P3 and more
I know this is an old thread, but I'm intrigued.. So we've established the clock is set by IR... but what in the car sends the IR timing signal to the clock and where the sender IR is? I'd like to find it & decode it.
It's things like this which make me enjoy Mercedes. Sure, a lesser car could run a data wire to the clock and build a clock with a bus interface on the back...but Mercedes decides to design one that only needs power. I'm sure this was done due to this being a facelift, thus allowing them to not need new wiring harnesses, but still...an elegantly simple solution.
Old Dec 11, 2014 | 07:31 AM
E350 Cab
I can't say for sure but I think it gets its data from the navi system. The GPS gets precise time from the satellites. I'm sure the clock has a microprocessor and stepper motor to move the hands. I just got a new Porsche Cayenne and to set the clock you just tell the car your time zone. I know it is getting all data from the PCM (navi system). In the Cayenne every time you get in the car the Clock wakes up and the hands spin to the correct time.
Old Dec 11, 2014 | 10:19 PM
PJ550CAB's Avatar
2014 E550 Cabriolet, 2014 Porsche Cayenne Diesel
I've got a '14 Cayenne Diesel, parked next to my E550 Cab. Love that reset feature. The clock in the MB is very elegant, keeps perfect time. Porsche is spot on too.
Old Dec 12, 2014 | 12:42 AM
BeachBunny's Avatar
Hmmm... sounds like it's experimentation time. Looks like I'll be stopping by the stage lighting store for some IR filters on my way to pick up my car later this month.
I'm not sure I'd be real happy about the clock going to sleep. Dramatic effect, maybe...but I expect a clock to have the correct time whenever I look at it.
