Most aggressive set-ups for 19s
Old Nov 19, 2013 | 07:27 PM
fullvietfx's Avatar
AMG GTS
Hello everyone I'm about to purchase a used 2011/2012 Mercedes-Benz E350 or E550 Coupe, which ever I find first in a white/red color combination. My question to you guys is what is the most aggressive set-up this car can take in 19s? After doing a bit of research it seems 245/35/19 in the front and 275/30/19s is the max I can go. Has anyone run anything more aggressive than this? Another thread on here had someone running 255s in the front but there was a bit of rubbing.
Old Nov 20, 2013 | 09:26 AM
Dueclaws's Avatar
'12 E550C, Sierra Denali
Do another search: there's a ton of info here.
Old Nov 20, 2013 | 10:47 AM
fullvietfx's Avatar
AMG GTS
I wish there was a sticky thread for wheels and tires.
Old Nov 21, 2013 | 12:00 AM
fullvietfx's Avatar
AMG GTS
Would 19x10 +30 fit in the rear? I'm willing to roll my fenders.
Old Nov 21, 2013 | 12:22 AM
gavrocool's Avatar
e350 coupe
NO WAY.
Old Nov 21, 2013 | 09:24 AM
fullvietfx's Avatar
AMG GTS
Originally Posted by gavrocool
NO WAY.
What would you recommend?
Old Nov 21, 2013 | 10:32 AM
Dr-Nab's Avatar
B8.5 Audi S5 3.0 TFSI Coupe
if you want to go 19x10 then +45 ?
Is the car standard ride height or lowered? Or do you plan on lowering the car?
Old Nov 21, 2013 | 01:31 PM
gavrocool's Avatar
e350 coupe
For a 10" width is recommended to lower the car if you want a nice clean look,Maximum low offset is 42,it is the lowest i have used,now i use +45.
Old Nov 21, 2013 | 01:58 PM
GerryMac's Avatar
2012 E550 Coupe
So many variables ...
Also depends on the rubber that you intend to use. If you go with 275's then Nab and Gavro are correct that et45 would probably give you the most flush fitment, however, if you want to run 285's then you may want to consider et50 for a flush fitment. I am running 19X10et50 with 275's and am happy with the fitment, some might prefer a more aggressive poke with et45.
Old Nov 21, 2013 | 08:10 PM
fullvietfx's Avatar
AMG GTS
No plans to drop the car. I wouldn't mind a 9.5 wheel but how does a 275 tire look on a 9.5 wheel? I guess I could go with ET35 on a 9.5 wheel?
