Does the C207 (2010-2011) 7G Tronic Require Transmission Fluid Change
Old May 24, 2014 | 07:56 AM
nauticalx's Avatar
I'm reading conflicting reports online, does the 7G Tonic Transmission Require a fluid and filter change per MB recommendations?
Have a 2010 E550C here.
Also, is the E350C and E550C transmission the same?
Old May 24, 2014 | 08:43 AM
theraven333's Avatar
Mercedes E350 CD Iridium silver convertible 2010
Yes !! I have the E 350 CDI Cab, and they changed the oil/fluid and filter after 2 years ? x miles. It is definitely part of the maintenance schedule, so I would have it done !!!!!!
Unfortunately the fluid is not cheap so it appears to be expensive for what it is and I think many people fail to have it done........ unless you have a maintenance contract
Old May 24, 2014 | 03:37 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
The service interval for a 10 E550 is 4 yr 40k... or to be done with the 40k sevice interval.
The newer fluid it has been extended to 7 70
Old May 29, 2014 | 08:45 AM
Dr-Nab's Avatar
B8.5 Audi S5 3.0 TFSI Coupe
I had 3 year/30k service done earlier in the year and assumed the ATF change was due, dealer told me not due yet, possible it will be 4 year/40k
Old May 29, 2014 | 09:39 AM
C230Brit's Avatar
2010 E550 Coupe
As with other replies - definitely required. I am getting mine done as part of the 50K Service B which I am having done next week.
Service Advisor stated cost as $400.
Old May 29, 2014 | 02:12 PM
hillcreative's Avatar
2011 E350 Cabriolet
Just went to a free spring service inspection and the dealer told me the car needed a transmission service fluid, filter etc. The car has 46K miles and recently had its "A" service. When I tried to schedule the car for the tranny service they couldn't get me in because of the free spring service inspections they were doing! I called my other dealer in West Chester and they said bring it over and we'll fit you in. They also charged $100 less than the "busy dealer."
Old May 29, 2014 | 03:23 PM
I am in the UK and my dealer did it last December (3 years with 34K) as part of the maintenance schedule for the model, I do have a Mercedes Service package for 4 years which ends in 2016, whilst it costs, it works out being a much better deal than taking each service as and when, and I also cover things like the transmission fluid without thinking about the direct cost. for those still in the warranty window it is worth investigating the service package????? Actually works out to be a large saving over the 4 years......
I have also taken out an extended warranty for 3 years, ( I had to pay for the new wind deflector (aircap)above the windscreen, £1200 ouch as my car is out of warranty and it is the 3rd one on the car).....To be fair to Mercedes they did make a large contribution.
Old May 29, 2014 | 06:58 PM
steelgrey's Avatar
E350 Coupe
I just had my 2010 E350 Coupe in yesterday for it's 4 year maintenance. The total cost was $1319.06. They serviced the trans, did an oil change, changed the intake filters, changed the in-cabin filter, drained the brake fluid and refilled and installed new wiper blades. Getting routine maintenance on these cars is not cheap!!! I plan on keeping the car a few more years and like having a verifiable maintenance trail.
Old Jun 2, 2014 | 01:20 AM
tw8715's Avatar
E550 Coupe
wiper blades and filter done at home would cost you a lot less.. even oil change if you can do it.
Old Aug 20, 2015 | 02:24 AM
$100 GUY's Avatar
C207
Has someone done the trans fluid n filter change?
I have read different things of when this thing has to be done, like, I would change fluid & filter every 60,000Km's like other Benz transmissions
or that you should change it every 3 years or 31k miles.
This is for the 7G tronic plus
Old Aug 20, 2015 | 04:48 AM
Mine was done after three years , about 30,000 miles as part of Mercedes-Benz own service contract, I was surprised they did it when they did as I had expected about 60/70k miles, My last BMW had lifetime oil, which I think is a load of crap, so happy that Mercedes follow a different approach.
Old Aug 20, 2015 | 01:29 PM
$100 GUY's Avatar
C207
Good to know man.
Better to change it based on mileage or in terms of years?
I have read the procedure, it says you need STAR to do it (to measure the fluid temperature)
Where can I get this STAR equipment?
Old Aug 21, 2015 | 09:41 PM
$100 GUY's Avatar
C207
Well, given the time and mileage (40K) required, don't have to do it.
But, I still want to know which STAR equipment is the best buy.
I already have WIS and brake fluid change is something to be done more often.
Old Aug 23, 2015 | 03:50 AM
lee16's Avatar
2010 E550
When did the newer fluid come out?
Old Aug 24, 2015 | 07:10 AM
hcetzneb's Avatar
Was changed mid-year 2012
Easy way to spot it the different tranny pan.. Has a deeper pan design.
Old Aug 24, 2015 | 08:37 AM
here is the maintenance schedule, whilst for the US I believe it applies to other countries
I have done it as a PDF attachment
File Type: pdf
