Easy first question. Windshield washer nozzle.
Old Apr 3, 2016 | 11:29 PM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
Is there any way to adjust the spray pattern? Not sure how to say this without getting comments, but I would like to adjust the spray higher up the window. Thanks.
Old Apr 4, 2016 | 06:20 PM
smiles201's Avatar
Figured it out (I think)
Ok, I guess it is a standard nozzle. Found a high end adjustment tool on Amazon, no cheap metal pin for me! Thanks.
Old Apr 4, 2016 | 06:56 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
any pin would suffice
Old Apr 11, 2016 | 06:51 PM
smiles201's Avatar
Ok, back with same question. It does not look or feel adjustable. There is hole in center and two slots, one above and one below on each nozzle. No movement with gentle attempts. I used to have an Audi with nozzles with very limited adjustment, may have to live with it I suppose. VIN WDDKJ8JB9DF199935
Old May 3, 2016 | 10:43 AM
Tennis Dad's Avatar
2023 EQB250+; 2004 CLK320 Cabriolet
It would not appear the spray angle is adjustable and I find it to be a little low on the windscreen as well. However, my bigger problem was that one of the nozzle units was broken on the 2010 E350 coupe i just purchased. The mechanics at Big O tires were able to diagnose the issue. There is a small ball bearing in the bottom of each unit that had fallen out in my middle unit causing most of the fluid to be dumped and leaving no pressure for the others. They were able to bypass this unit so the the other two now function until i can get a replacement part from MB.
Great work from Big O tires!
Old May 3, 2016 | 05:42 PM
smiles201's Avatar
There is a tool that may fit our nozzle, not sure if this is right for a 207 however 001 589 02 16 00
Old May 3, 2016 | 08:07 PM
Tennis Dad's Avatar
Thanks, that looks like it would work
