Odd Things Taking Place
Old May 2, 2016 | 09:48 AM
Richard_P_Harve's Avatar
2016 E400 Coupe Mars Red
My 2016 E400 has recently been acting up electronically. There have been several occasions recently where it says "no key present" even though the key is in my hand. I've been forced to remove the push button and insert the key in order to start the car. There have also been a number of weird events take place, like the passenger window rolling down all by itself or the button on the audio system not working. Have not yet addressed this with the dealer but wondered if anyone has experienced anything like this.
UPDATE - Just went out to pick up some lunch and got an error / warning on the dash suggesting that brake and tail lights were out, yet they were working fine. Sounds like it's time for a dealer visit.
Old May 2, 2016 | 11:54 AM
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
Please take it back.....Our cars are far too expensive for the BS......and you got a new one at that.......Let us know what the dealer says
Old May 3, 2016 | 03:52 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
I've had the "Key Not Detected" message on my E400 one time. I had to take out the Keyless Go button and start the car with the key. I then shut the car off and replaced the button, and all worked correctly.
My wife has had various window gremlins and also the Key Not Detected on her GLK. She has also had various door handle malfunctions. Always the issues can be "repaired" by using the lock then unlock buttons on the remote.
I have discussed this with our service advisor and he indicates that these are too common with all of the newer MB's, and that they really do not have a concrete fix. If a car repeatedly exhibits the same issue, then maybe they can find a cause. If it is a seemingly random issue, they say to just reset it with the remote buttons and move on.
Good luck.
Old May 3, 2016 | 04:32 PM
I forgot about the door handle issue, had that too several times. Walk up to the door with the key in my pocket, touch the inside of the handle and nothing. Needed to physically press the unlock button on the remote to get in.
I'm going to chat with dealer about this but I'm not impressed with what the dealer told Steve.
Old May 18, 2016 | 11:20 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
First check you key batteries, I've seen a weak key battery make the keyless go system
go a little nuts.. Also there is a update for the keyless module that has helped this issue
Old May 19, 2016 | 08:25 AM
I took the car to the dealer and they did some kind of update or re-load and so far (1 week) it's been ok.
Old May 19, 2016 | 03:37 PM
retvethogrider's Avatar
2015 E550 Coupe
When I had the no start problem except when manually inserting key, I swapped out the batteries in the keyless remote. Has worked fine ever since. The battery swap is piece of cake.
Old May 20, 2016 | 10:33 AM
NCBob's Avatar
2012 C63; 2011 E350 Coupe
When the batteries in the remote are in need of changing, I get a message on the Command screen.
Old May 20, 2016 | 12:19 PM
2015 E550 Coupe
Good point. I did not know that. I never received the warning. Just changed the batteries. All well after doing so.
Old May 23, 2016 | 01:34 PM
PJ550CAB's Avatar
2014 E550 Cabriolet, 2014 Porsche Cayenne Diesel
Rumor has it that key batteries last longer when they are taken out of the car. Originally left my keys in the car in my locked garage, the batteries would only last a few months. This doesn't seem to be an issue now that I take them out and store them elsewhere in the house.
Old May 23, 2016 | 03:32 PM
2015 E550 Coupe
Aw, good to know. Thanks
