Cigarette socket at Center Console Wiring Questions
Old Jan 30, 2017 | 10:25 PM
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
I like to add / splice a female cigarette lighter socket to the existing front cigarette socket under the ashtray at the center console for my dash cam. I do not want to touch the fuse panel.
As I know, there is a white color plug that connected to the cigarette socket. I like to splice the positive wire and the negative wire from the new female socket to the wires from the cigarette plug. However, I do not know which wire from the plug is positive or negative.
Anyone knows? Please help, thanks.
Old Jan 31, 2017 | 10:02 AM
pca7ggr's Avatar
'11 E550 Cpe/'04 GT3
Instead of "splicing" into the car's wiring harness, just get a "piggyback" fuse/hot lead and plug it into a switched fuse socket?
https://www.amazon.com/Bussmann-BP-H.../dp/B000GKEXK2
Old Jan 31, 2017 | 12:23 PM
Ultraman's Avatar
Yes, I know but you have to get a dash cam kit as well to convert the 12V to 5V as well to the dash cam. As I mentioned before, I do not want to touch the fuse box as for the DIY project.
The reason that I want to tap a female cigarette socket to the existing cigarette socket plug because I just want a simple set up. Since the ashtray door cannot be closed now due to the car adapter and the usb cable, the only simplest way to solve the problem is tapping the wires so that I can hide the new female cigarette socket, car adapter and the USB cable under the glove box.
Old Feb 1, 2017 | 09:42 AM
2150john's Avatar
E 450 4matic cab MY22
Product Details
Car Mate CZ206A 15 Amp 2-Way Auxiliary Socket Adapter - Pack of 1
You might want to do a search for this on Amazon. It or something like it could be a simpler solution.
Old Feb 1, 2017 | 10:31 AM
Ultraman's Avatar
Originally Posted by 2150john
Product Details
Thank you for your suggestion but what I want to do is NOT to put the car adapter to the coin tray so that I can close it.
Old Feb 1, 2017 | 11:23 PM
laramr's Avatar
2012 E550 Cab
Have you looked at tapping into the rear view mirror?
Old Feb 2, 2017 | 12:36 AM
Ultraman's Avatar
No. The wires behind the cover on the windshield involved so many wires. Also, it is very hard the hide the excessive dash cam wire behind the cover.
The ideal location is still splicing the wires from the cigarette lighter socket under the the ashtray at the center console.
Old Feb 2, 2017 | 08:56 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
So you dont know and cant figure out power and ground but you want to mess with the electronics in your car? that sounds like a great idea.
Old Feb 2, 2017 | 09:21 AM
Ultraman's Avatar
I am going to use a multi-meter to find out the power. If it is so complicated, I will take it to a shop and install the dash cam kit with fuse.
Old Mar 4, 2017 | 03:59 PM
damionphillips's Avatar
17 S213 E400 87 E30 325is 08 Acura TL
Love to see a pic when you've got it completed..
